Beat Wheel studs out?
Old Apr 20, 2006 | 05:47 PM
Klamath Stoogie's Avatar
Klamath Stoogie
Default Beat Wheel studs out?
The shop I had my state safety inspection done at stripped two of my wheel studs. They said they'll replace them, but I'm afraid they want to beat them out. The GM manual says to remove the hubs and use this little c-clamp kinda tool to remove the rear wheel studs on my '91.
Is it ok to beat them out?
Has anyone here ever replaced wheel studs without removing the hub?
Old Apr 20, 2006 | 06:20 PM
Pete K's Avatar
Pete K
A bfh works fine. Whack them out.
Old Apr 20, 2006 | 07:40 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Old Apr 20, 2006 | 07:52 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Originally Posted by Mr Mojo
We do it all the time
Old Apr 20, 2006 | 11:57 PM
Blown Vette's Avatar
Blown Vette
Don't beat them out. Use a big C clamp with a socket on the back of the stud to allow it to travel out. To simple a job to risk damage to the bearing hub.
Old Apr 21, 2006 | 12:03 AM
Mr Mojo's Avatar
Mr Mojo
One whack with a hammer and it's out lickety split, no damage so far.
Old Apr 21, 2006 | 01:50 AM
DieL's Avatar
DieL
I tried using a clamp setup on my 93 a few years back.. took me hours and hours to do one wheel. i started to whack them out.. and it was instant i was putting in drm longer studs because i had spacers on to fit the y2ks better. I ended up putting gm wheel bearings back on all 4 wheels last week because i needed short studs and guess what.. 3/4 bearings had play in them. i can't say it was from the wacking.. but its always been on my mind since i did it.
Old Apr 21, 2006 | 07:47 AM
mseven's Avatar
mseven
yep, and since no one addressed install, put new one in, put washer on it and a lug nut, tighten till all the way seated (as viewed from back side). Remove nut and washer and install tire. I know there is a stud tool or press also, that I think is unnessesary simply because you would probably have to remove the rotor at that point.
Old Apr 21, 2006 | 07:55 AM
Tom Piper's Avatar
Tom Piper
Even though it works, I don't like beating on anything associated with my wheel bearings.
For my wheel studs, I use the ball joint separator on the left in this link:
http://www.jcwhitney.com/autoparts/P...Ntt=ball+joint
Edit: Works every time in seconds, but you do have to remove the rotor.
Tom Piper
Old Apr 21, 2006 | 08:27 AM
Klamath Stoogie
Actually, the GM service manual says to install them using washers like you describe.
Thanks for the replies, everyone.
Old Apr 21, 2006 | 10:36 AM
redrose's Avatar
redrose
i don't like the harley wrench method (bfh) either...i put lug nut on the stud if i can, put a socket on the back side (socket size large enough for the stud to slide into)..put a big c-clamp on the whole mess and tighten the clamp as much as i dare..then just give the end of the c-clamp a little whack with a small hammer and pow--the clamp and the socket fall on the floor (i lay cardboard on the floor first-save the floor) and the lug/nut is loose in the hub
Old Apr 21, 2006 | 10:40 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
That's what I was thinking; once there is tension on the stud all it should take is a little "persuasion" to break the corrosion.
Old Apr 21, 2006 | 07:47 PM
Aggravated4life's Avatar
Aggravated4life
The BFH trick works great...also,on reinstall,I use a bearing race to put over the stud and tighten the lug nut down against the race with a big 1/2 inch drive ratchet/socket.It pulls the studs through hub with ease.The inside hole of the bearing race should be large enough to allow the stud to pass through,but small enough to keep the lug nut from pushing inside.
Old Apr 21, 2006 | 08:43 PM
Mr Mojo's Avatar
Mr Mojo
I have the extra long studs, so I used a few washers
Old Apr 21, 2006 | 08:45 PM
Mr Mojo's Avatar
Mr Mojo
Well from experience, the studs I beat out, the hubs are fine, the car I never took studs off of have bad bearings, so whacking with a hammer isn't going to affect them.
Old Apr 21, 2006 | 08:48 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If it was my mistake I wouldn't mind beating them out. But since it's their mistake, make them do it the right way and press em out with a clamp or press.
Beating on them will affect the wheel bearings (how much I don't know) but if one goes out on you in 2 months after their hammering, you'll hate yourself.
Pete K's Avatar
Pete K
Yup. I probably smacked out a couple hundred with the Harley wrench. Never had an issue. If anyone feels the need to press them out, have at it. On paper, it certainly is the better way to go.
To Beat Wheel studs out?
Old Apr 21, 2006 | 09:00 PM
mseven's Avatar
mseven
I'd say so, looks like all the lug washers, and then the parts bin.
Old Apr 22, 2006 | 12:39 AM
jfb's Avatar
jfb
The studs were pressed in and should be pressed out. Beating on pressed in items usually ruins the item by mushrooming it and preventing the mushroomed end from going through the hole AND beating on bearings is the perfect way to ruin them, not to mention distorting the hole or the body that the stud is pressed into.
Old Apr 22, 2006 | 09:44 AM
Mr Mojo's Avatar
Mr Mojo
You make a good point and if I was to have a professional do it, I would have them pressed in. But from personal experience, I have never encountered mushrooming of the parts by beating on them.
In the pics above, those studs were beat out and pressed in three times so far, if they are mushroomed, I certainly don't see it.
Remember, it's one whack and it's over, it isn't like we're beating on each stud for 5 minutes.
The one thing that worries me about the constant removal and installation is the grooves in the flange wearing down and losing their grip.
