Broken window stops
Old Apr 20, 2006 | 11:49 PM
dbaction's Avatar
dbaction
Default Broken window stops
Hey guys ... Does anyone know the actual GM number for 1994 - C4 window stops??? Iv'e searched the forum data base, the aftermarket, and the GM Direct but no luck. The windows both raise too far at the front and the rear of the window hits the roof support ... took the door panel off and repaired one of the stops with adhesive but it broke after a couple of weeks. Any help appreciated.
Don
Old Apr 21, 2006 | 09:07 AM
RRT vette's Avatar
RRT vette
I have the same problem on my driver side door. I can get the part from GM for $12 and got a quote from a local body shop to install for $40. There is a need for some special tool on the back side of the stop that is not visible unless you have a mirror that will fit into a tight space. I haven't done this yet but I think $40 will save me from pulling my hair out.
Old Apr 25, 2006 | 11:23 PM
dbaction's Avatar
dbaction
12 bucks sounds cheap enough. I used a spanner wrench from a hand held grinder to remove the bolt. A flat metal bar about six inches long 1 inch wide with two pins about 1 inch apart.
Any idea what the GM part number is?
Old Apr 25, 2006 | 11:58 PM
VenkmanP's Avatar
VenkmanP
Ask a GM dealer.
Old Apr 26, 2006 | 12:05 AM
86PACER's Avatar
86PACER
Originally Posted by Vis Croceus
Ask a GM dealer.
Some GM Dealers refuse to give out part numbers to you over the phone.
Old Apr 26, 2006 | 12:09 AM
VenkmanP's Avatar
VenkmanP
Ask a GM dealer that doesn't suck.
Fixed it, thanks.
To Broken window stops
