90, Tachometer Problem
Old Apr 21, 2006 | 07:16 PM
wombvette's Avatar
wombvette
Default 90, Tachometer Problem
Gents, maybe you can help me with this one. I have a `90 in the shop that the tach. is reading way too high. It works but is too high. Is this something that is common with this dash? I have gone though the prelimanary checks and it points to the tach being bad, but I hate to replace the thing and that not be the cause of the problem.
Old Apr 21, 2006 | 08:07 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Mine reads about 500 RPM too high. ('91 Vette)
There is no adjustment for it that I'm aware of.
There is a 'Tach Filter' out by the distributor that you could try changing before you change anything else.
Old Apr 21, 2006 | 08:24 PM
bogus's Avatar
bogus
these tachs are not the most accurate...
if it was the tach filter, it would be reading really wack... how high is high? if at idle it's reading 5000, then the filter is hosed.... otherwise, I would either ignore the problem, or, get an aftermarket tach if you race (which is VERY important). Then again, the L98 has a built in rev limiter - it's called "TPI."
Old Apr 21, 2006 | 09:07 PM
Jerris's Avatar
Jerris
The tach on my 92 reads about 600 RPM too high. I just factor this in when I read the tach.
Old Apr 21, 2006 | 09:37 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
The tach on my 90 reads from 500 rpm high at idle to 2k or so on the high end (according to datamaster, anyway). Makes for an interesting ride sometimes.
Old Apr 21, 2006 | 11:23 PM
wombvette's Avatar
wombvette
OK, sounds like the condition is rather common. It will read 500+ high at idle and then go way up when you rev it a little. The scan tool indicates a normal signal and reads correctly.
Old Apr 22, 2006 | 10:21 AM
jimmers's Avatar
jimmers
My tach reads around 600-1000rpm to high. The odd time it wont be way off, but normally it is. Its really annoying.
Old Apr 22, 2006 | 10:37 AM
rick lambert's Avatar
rick lambert
According to Gordon Killebrew-most tach problems are because water entered the bulkhead connection-and the tach connection is on the bottom row.Although I agree with digi tachs not being all that accurate.
Old Apr 22, 2006 | 03:29 PM
wombvette's Avatar
wombvette
Thanks Rick, I will give that a look see, but the 90 is not digital.
To 90, Tachometer Problem
