R-134a Quick Cool? Does it work?
Old Apr 22, 2006 | 01:34 AM
slicked25's Avatar
slicked25
Default R-134a Quick Cool? Does it work?
I saw a can at the part store today and it has a tube on the top of it that attaches to the low pressure end. If I have R-12 could you still put this in with it? Otherwords can R12 and R-134a mix?
Old Apr 22, 2006 | 01:52 AM
93*Corvette's Avatar
93*Corvette
Two thread are going on at the same time concerning this topic... Check out http://forums.corvetteforum.com/show....php?t=1371533 Hope that helps...
Old Apr 22, 2006 | 07:46 AM
comp's Avatar
comp
Old Apr 22, 2006 | 10:56 AM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
No. The are kits to use when converting from R12 to R134. They incluse new seals, O rings and oil.
Old Apr 24, 2006 | 02:45 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
The R134a boost kits are just snake oil, IMO.
At best, you'll gain a little extra oil for your seals and compressor, but I haven't noticed any significantly (read MEASURABLE) lower vent temps in my vehicle.
Old Apr 24, 2006 | 02:51 PM
aminnich's Avatar
aminnich
NO, they don't mix. Plus, it is really not good idea to just add freon to ac system without gauges to be sure pressures are to spec. Too little freon means poor cooling, too much means poor cooling, plus possible system damage from excessive hi side pressure.
Old Apr 24, 2006 | 03:35 PM
runner140*'s Avatar
runner140*
No...they absolutely do NOT mix.
kalister1's Avatar
kalister1
The fittings are different between the 2 types of gases.
To R-134a Quick Cool? Does it work?
