I just got started on my opti spark and water pump (radiator removal and cleaning, wire replacement and intake manifold sealing) replacement. I drained the radiator. Next was to remove knock sensors to drain the rest of the coolant. Here's my problem. I put a 7/8 deep socket on the sensor and it looks like the inner part is moving but the outer part isn't. What's up with this? Is the sensor a two piece part? How are you supposed to get it out. All help is greatly appreciated
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I had the same problem with one of mine the first time I removed it. No, it is not supposed to do that. It's because the bottom section is stuck in the block due to age. The good news is, it's easy to get out (or should be), just put a pipe wrench on the outer diameter to get it broken loose. The bad news is, the sensor should probably be replaced, now that it's turned within itself. They're not that expensive though and if you've got some mileage on your car, it might be a good time to just replace both. When reinstalling, these needn't be real tight. I can't remember the torque spec but it ain't much.
Originally Posted by Thomastp
Thanks Chris. I'll give it a try. I guess GM is the only place to get the knock sensors though.
No, not the only place. But if you get them from Superior Chevrolet, who's a forum sponser, they're not bad at all. I got one from a parts store a couple of years ago and it recently failed. The other one, which was original to the car, was still working. I now have two new GM ones in the car though.
Superior Chevy 800-728-8267 Ask for Chris Mays in parts and tell him you're a forum member. You'll be gold!
I just finished a water pump on my '96 today. It is worth it to get as much coolant out as possible. The worst part for me was the middle water pump bolt on the driver side as it is directly behind the power steering pump pulley. I think it is well worth the time to get a puller and get that pulley off, although the manuals say it is not necessary it sure made the re-install much much easier.
Second worst problem was getting the old water pump gaskets off. spray with gasket solvent, scrape with razor blade, and repeat and repeat and repeat...drivers side is very hard to see. Take your time and get the surfaces clean.
Finally fired her up this afternoon and so far so good. We'll see.
