Engine Building Forums
Old Aug 21, 2001 | 12:02 AM
Jimi Lane's Avatar
Jimi Lane
Default Engine Building Forums
does anybody have the address to a good engine building forum?
jimilane
Old Aug 21, 2001 | 04:08 AM
GlockLT4's Avatar
GlockLT4
Default Re: Engine Building Forums (Jimi Lane)
Yeah, that would be nice to have. I've always wondered if I could do a rebuild myself. Obviously I won't do one to my vette now since it is a daily driver, but as a project in the future. I've even thought about buying an LT4 from a scrapped vette and spending a long while rebuilding it and fixin' it all up with some goodies and putting it in mine. But that won't come until I get another vehicle as a daily driver.
Old Aug 21, 2001 | 04:29 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I don't know of a Forum for engine building but both Dave Emanuel's and John Lingenfelter's books are great and availble on Amazon. Though it will still be a bit of a learning curve.
Old Aug 21, 2001 | 05:55 PM
Rick86's Avatar
Rick86
Check with your local community college, they usually offer automotive classes, plus they have the tools and instructors to answer your questions.
Old Aug 21, 2001 | 06:01 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
If you have to ask HOW TO, You shouldn't :(
Old Aug 21, 2001 | 09:01 PM
Jimi Lane's Avatar
Jimi Lane
Default Re: Engine Building Forums (mackeyred96)
Late last night, while assembling this engine out in the shop, I found that the spring in the Comp Cams, flat tappet, hydraulic, Pro Magnum lifters, would not push the plunger up to the retainer. Never seen one like that before.
Makes it kinda hard to set a 0.002-0.004" pre-load, at the lifter, when the plunger is way down below the retainer. I thought I might find some info on these lifters at some secret voodoo engine building forum, for people that build engines in the middle of the night. No such luck.... I called Comp Cams today and actually got a hold of the "Cam Help " guy. SOOO...to make a long story short...........That's the way they are suppose to be...The plunger doesn't make it to the retainer...these lifters won't float a valve until 7200rpm (so Comp says), they should be set at zero lash for break-in and for max power. To quiet them down, you can put 0.002-0.004 pre-load, and not loose any power. The MAX pre-load is 0.010"
Hey Mackey, if anybody askes you to set up their hydraulic Pro Magnum Lifters, tell 'em ya know HOW TO......
Next time,
jimilane
To Engine Building Forums
