TPiS Headers Install - 1985
Old Apr 23, 2006 | 07:03 PM
GRX's Avatar
GRX
Default TPiS Headers Install - 1985
I just got finished test installing my ceramic coated tpis headers and y pipe, I got this week (took 2 months to get 'em).
Issues: The flange mounting holes where too small - had to enlarge them in order to install on AFR heads.
At least I didn't need to 'dent' the pipes to make it fit. Weld quality was superb as was the finish. Packaging was excelent to.
Question: What are you guys doing about the proximity to the gas lines? ...and in my case, the headers are close to the clutch master hydraulic hose.
TIA.
Old Apr 23, 2006 | 07:31 PM
vader86's Avatar
vader86
I wrapped everything in a heat-resistant tape.
Old Apr 23, 2006 | 08:39 PM
jeffyc's Avatar
jeffyc
i bent mine as best i could and then tye wraped the lines so they would be as far away as i could get them
its still closer then i like
(i used a bunch of tye wraps just in case not like 2 or 3 more like 10+)
Old Apr 23, 2006 | 10:49 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
Re-routed them...
Maybe a little overkill, but I really did not like it and the inlet is very accessible on the back of the Miniram fule rails.
The valves in the first pic were removed shortly after the picture was taken. Something about their seals and gas not going together well. The one on the return had been there from the previous owner for some time so I didn't think it would be an issue, but decided not to test fate.
Old Apr 24, 2006 | 12:18 AM
GRX's Avatar
GRX
Thanks for the pics!
Old Apr 24, 2006 | 01:04 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Do you have any photos of the headers installed?
Old Apr 24, 2006 | 01:34 AM
GRX's Avatar
GRX
I'll take some tomorrow.
Old Apr 29, 2006 | 12:23 PM
GRX's Avatar
GRX
Central, here are some pics. I had the header just snugged on.
Its nive by the mini-starter but tight by fuel/brake lines. Big surprise huh?
Old Apr 30, 2006 | 05:14 PM
CentralCoaster
Man that is tight. I guess they left room for the big starter. Almost makes me want to try to make a set myself. If I get a house this year, first thing I'll do is set up the garage. Pneumatics and a welder, and medical lab lighting.
To TPiS Headers Install - 1985
