unsprung weight
I think Weld are the mose inexpensive light weight wheels you can get.. IF you like that look.. you can see mine in my sig.. well the fronts only.
of the OEM '89 wheels, OEM '03 Z/06 wheels (9.5" & 11" Speedline),
Goodyear GS-C, F1 and Hoosier tires.
These threads might be of interest
http://forums.corvetteforum.com/show...post1544609448
http://forums.corvetteforum.com/show...post1543702573
2003 Z/06 wheel, cap and 265/? x 17 GY F1 SC tire : 44 lbs
2003 Z/06 wheel, cap and 295/? x 18 GY F1 SC tire : 49 lbs
Z/06 Wheels & caps only:
- 17 x 9.5 = 19 lbs
- 18 x 11 = 20 lbs
Hoosier 305/30 x 18 = 24 lbs (44 lbs mounted on Z/06 18 x 11)
but not where I can look them up just now. I'm not going to guess,
but you can look at the weight of the 17" Z/06 (w/ slightly smaller tire)
and compare against the 17" '89 OEM and see that there is a 7 lb
difference. Multiply this by four and you are looking at a significant
difference. The difference is a bit less when comparing with the same
tire but it is still substantial.
(Note that the aftermarket Z/06 wheels said to be heavier than the
OEM Speedlines.)
Check the link I posted above for an idea of the effect on accelleration
and braking arising from a change of this magnitude.
Is this a worthwhile change? It depends.
I had multiple reasons for changing (C5 brakes, 18" track tires & performance).
I bought two sets of Z/06 take-offs, so I was able to transfer my GS-C
tires to the four 17" fronts and immediately drive the car following the
wheel change. I feel that ride and acceleration improved with the
lighter wheels.
The impetus for the question was finding one of the weight/hp threads on this forum and in lifting my friends' aftermarket Evo wheel.
What I didn't think about was the fact that his wheel was not fitted with a tire, whereas my spare wheel is.
I'm a dummy.
I've used Weld Pro Star Wheels & they are about as light as you can get.. & are sharp looking (IMHO)
I have a pair of after market A mold 17x11 on the rear.... my neighbor also wants a set.. 17x11 I think I bought mine (5 yr ago) from AAA but they don't have them now..
I need 17x11 with the 56mm backspace.. it HAS to be more than the factory Grand Sport wheels because the Grand Sport wheels stick out too far on a regular C4
I'd appreciate any tips on where I can get a set of these...
thanks in advance... I'm sure someone will know.. (I hope)
