Power Window Swich/ Courtesy Lights
Old Apr 24, 2006 | 01:06 AM
CJB's Avatar
CJB
Default Power Window Swich/ Courtesy Lights
I recently installed a new power window motor and switch. When the other motor was dying the window switch light worked, but would sometime stay on all the time, or eventually die out. The small light bulb in the courtesy light array behind the orange filter also went out around the same time. A circuit tester showed complete power to the window switch, but no power to the courtesy bulb behind the orange filter. Any help in tracing these problems much appreciated.!!
