406 binding problems
Old Apr 24, 2006 | 10:07 AM
88421VETTE's Avatar
88421VETTE
Default 406 binding problems
Ok so today I pulled the heads off the 406 and the cylinders look perfect so I pulled the pan hoping to see something binding it up. Nothing here's the prob I can get the motor to turn completly around but it hits one spot that gets really tough like it rubbing somewhere. it does it in the exact same place everytime. Once it gets past that point it's fine. so does anyone have any ideas as to where it could be rubbing.
Old Apr 24, 2006 | 10:52 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Is this a motor that your putting together on a stand, or one that you have been running?
Need more information....
If its one that you putting together on a stand, what are the clearances at? Mains? Rods?
Old Apr 24, 2006 | 11:13 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Check for rod bolts hitting block or, if you have a VERY high lift cam, interference between crank ***'y and a cam lobe.
Larry
code5coupe
Old Apr 24, 2006 | 11:22 AM
CFI-EFI's Avatar
CFI-EFI
Depending on what you are using for rods, you could easily have a rod (or rod bolt) to camshaft interference problem, and THAT can happen even with a stock cam. The cam isn't going to hit the crank.
RACE ON!!!
Old Apr 24, 2006 | 11:26 AM
rocco16's Avatar
rocco16
That's why I said "crank assy"....I couldn't remember if it was the throws or the rods (which are part of a "crank assy")that were the problem. Thanks for clearing that up, CFI.
Larry
code5coupe
(I'm rapidly getting to that life's stage where I've forgotten more than I ever knew. )
Old Apr 24, 2006 | 01:47 PM
Ramanstud's Avatar
Ramanstud
turn the motor over (By HAND!) until you feel it start to bind. Then get out a flashlight and look for anything that's touching. I'm assuming the oil pan is off by now?
Hopefully it isn't the cam/rods touching, otherwise you've probably marred up a lobe...
To 406 binding problems
