Monoblade sticking
Old Apr 24, 2006 | 10:52 AM
importkiller92's Avatar
importkiller92
Default Monoblade sticking
I installed a monoblade on my '92 supercharged L98. I know it is overkill for it, but I got a good deal when I bought it with a miniram. I put it on my stock plenum and manifold, and it sticks. The idle will not go below 1500 no matter what I adjust it to, then it will stick at 3 or 4,000 out driving it. My thought is maybe the boost is holding it open. Any ideas or anyone who wants to trade for a 58mm?
Old Apr 24, 2006 | 11:07 AM
AKS Racing's Avatar
AKS Racing
The boost is not hanging the MB open.
You will find that there is mechanical interference. Remove the throttle and cruise cables and rotate the throttle lever open/shut. If it still binds, remove the TPS sensor (note the TPS reading with throttle closed, probably 0.56 or something close so that you may re-install in same position). If it still sticks w/out TPS snesor, then it can be bushings, or by some outside chance, a bent/misaligned throttle blade or shaft. I have seen this.
Did you loosen the throttle blade screws prior to install? The blade may not be properly aligned.
If you have given up on the MB, I have several billet 58s (Accel units), but I also have and run two (2) MBs. They will work.
Let me know if I can help further.
Aaron
Old Apr 24, 2006 | 01:07 PM
importkiller92
I have taken it off and it does not stick at all. It snaps shut and has no binding problems. I switched the IAC motor out of it with my old one that I know is good and I switched the TPS. I just don't get it. It only is sticky when the car is running.
Old Apr 24, 2006 | 03:24 PM
LT4POWR's Avatar
LT4POWR
No problems sticking here, but sometimes mine wants to idle in the 1200-1300rpm range. I'm too busy/lazy to mess with it right now. I think I remember someone saying something about a return spring on their's not being adequate and it was hanging open...I forgot who it was. Have you tried doing a search?
To Monoblade sticking
