stalls on start
Old Apr 25, 2006 | 12:42 AM
rightofway's Avatar
rightofway
Default stalls on start
most recent problem is when i start the car it will run for anywhere from 1-5 seconds then stall
anyone have this problem?
Old Apr 25, 2006 | 03:13 PM
kopbet89c4's Avatar
kopbet89c4
Had a similar problem like that. Engine would cut out and jerk suddenly or even stall at mid throttle. Threw no codes. 3 days later, I found out it was water in the gas tank. Iso Heat water remover and a new fuel filter were the solutions to the problem.
Is your problem right when you crank the car from a cold/hot start?
Old Apr 25, 2006 | 03:24 PM
rick lambert's Avatar
rick lambert
If you haven't already you may wish to check the fuel pressure-new fuel filter.
Old Apr 25, 2006 | 04:13 PM
RRT vette's Avatar
RRT vette
where I would start!!
Old Apr 25, 2006 | 04:21 PM
vader86's Avatar
vader86
an EGR valve thats stuck open could cause it too, but that usually throws a 32
Old Apr 25, 2006 | 07:00 PM
rightofway's Avatar
rightofway
no codes yet but and it hasn't been acting like water in the gas again
but it didn't do this today?
so was egr not used today then?
Old Apr 25, 2006 | 07:44 PM
vader86's Avatar
vader86
The system does a checkup on startup, every once in a while mine would stick open on startup (meaning once every few months).
It always threw a 32 on startup in that case.
Occasionally while sitting in traffic it would do the same thing, when the engine was hot. Indicating that something was wrong with my EGR sticking open intermittently when EGR conditions were met. (also every few months, not everyday by any means)
But i deleted the whole thing.
Old Apr 25, 2006 | 07:46 PM
rightofway's Avatar
rightofway
i plan on removing egr and all the emissions stuff once i move out of the parish
it's just a pain to work around
Old Apr 25, 2006 | 08:28 PM
rick lambert
Well, here's one for ya, my vette has not been throwing any codes, runs and pulls strong, maybe a little hickup-but NO CODES. Today I finally got the scanner up and running......guess what??? I have a code 34..MAF sensor low, I can deal with that with my FSM, but what surprises me is I had absolutely NO CODES SHOWING-i.e. NO FLASHING.
To stalls on start
