Heater Core for 93
Old Apr 25, 2006 | 07:38 AM
Jared1984's Avatar
Jared1984
Default Heater Core for 93
Well guys....I believe my heater core is shot I occasionally smell anti-freeze, My window fogs up from time to time, and yesterday I lifted up my passanger side floormat and the carpet felt like it had a real light mist on it. Sounds like the core....right? Anyways how can I make for certain it is the heater core before I take it to my mechanic to get done. I am not super mechanically inclined ( I installed my ram-air and can do little things) and just want to make sure. I drive the car once a week and dont drive over the cold winter months......so does it need to be fixed? All in all though I really just need a way to test if that is waht I think it is.
THANKS!!!
Old Apr 25, 2006 | 08:26 AM
kalister1's Avatar
kalister1
For a quick fix you can bypass the heater core, connect one hose to the other. There is a tool that you use to pressurize the coolant system to look for leaks. You can put dye into the system to help detect the leak, it comes in a kit with an ultraviolet light to detect teh dye.
Old Apr 25, 2006 | 08:34 AM
DRAKEFAMILY2's Avatar
DRAKEFAMILY2
You have all the classic symptons of bad core. I don't think you have to be a master mechanic to change just part contortionist. Been lots of posts on how to do, some even have pics. A lot of guys have removed passenger seat and dash pad as starting points, like i said use the search function and good luck.
Old Apr 25, 2006 | 09:47 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
The heater core and that darned Bose CDM tuner module (in locations under the dash) have to be among the worst C4 repairs going.
I just replaced my CDM box this past weekend and it was a major PITA.
Really aggravated my degenerative disc disease, I can tell you that.
Old Apr 25, 2006 | 10:08 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Sell it now.
Old Apr 25, 2006 | 03:39 PM
jimmers's Avatar
jimmers
Just replaced mine a few weeks ago. It was a big PITA!! Its not really that hard to do, its just a very small area to work in. There is a member on here Jet Jock that wrote a step by step guide with color pictures that helps alot. I used it when I replaced mine. Good luck!
To Heater Core for 93
