oil psi Q
Old Apr 26, 2006 | 12:15 AM
rightofway's Avatar
rightofway
Default oil psi Q
when i turn the key on without starting the engine shouldn't oil psi be at 0?
mine is always between 5 and 10
Old Apr 26, 2006 | 12:54 AM
bogus's Avatar
bogus
we are talking about GM sensors, here...
Old Apr 26, 2006 | 01:01 AM
rightofway's Avatar
rightofway
the sensors suck?
Old Apr 26, 2006 | 01:15 AM
vader86's Avatar
vader86
Any GM gauge is untrustworthy.
It could mean that the connector to the oil pressure sender is bad, or that the sender is going out. Thats what it is in my case.
Old Apr 26, 2006 | 01:28 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
vader, was that you that mentioned getting high pressure readings from a bad harness? What was your psi when off?
Because I'm at about 6-7 psi off, 75-80 psi running. I'd think if the harness was a problem, it'd add about the same psi whether running or off. It's gotta be a linear transducer.
To oil psi Q
