Headlights wont lock
Old Apr 26, 2006 | 12:48 AM
Demonic85's Avatar
Demonic85
Default Headlights wont lock
I replaced the gears in the driver side motor of my headlight about 2 months ago. Since then the nut holding the headlight and motor together has fallen off twice causing them to not work again. Its getting quite annoying and it doesnt help that I lost the original nut. So does anyone know what the size of the original nut is and where I can find it? Anything special about it? Certain torque it needs to be at?
Old Apr 26, 2006 | 12:52 AM
bogus's Avatar
bogus
use red thread lock.
Old Apr 26, 2006 | 01:06 AM
Demonic85's Avatar
Demonic85
If you look at the instructions on Mid-America's website for the installation of the gears...
http://content.madirect.com/pdf/601707.pdf
You'll see where it says in Step #3 to "remove the nut that secures the motor shaft to the pivot unit". I'm missing that nut.
Old Apr 26, 2006 | 10:36 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Call a Corvette salvage yard. They can sell you a burned-out headlight motor assembly you can use to scavenge parts from.
Old Apr 26, 2006 | 11:27 AM
Demonic85's Avatar
Demonic85
I'm pretty sure I can buy it at a hardware store if I knew what size it was.
Old Apr 26, 2006 | 03:21 PM
swifty's Avatar
swifty
I nobody comes up with the answer I'd suggest taking the one off the other side to determine size, then buy a locking nut (nylon insert) for less than a dollar at any hardware / home supply store. Good luck.
Old Apr 26, 2006 | 11:42 PM
Demonic85's Avatar
Demonic85
Thanks swifty, I really dont want to pull the other one, but looks like I may have no other choice at this point. And i'm definitely getting some thread lock.
Old Apr 27, 2006 | 12:07 AM
MrRenoman's Avatar
MrRenoman
Try an M8 x 1.25 nut. It's what's listed in my Parts and Illustration Manual. I noticed when the stock nuts go on, they self lock. I probably have some in my stash.
Art
To Headlights wont lock
