Case you're still pawning that horse-**** off to people While you're bogarting the Glenn Fiddich?
Here I'll share something good and pass off the hopes that tech goes back to being tech and not some ego trip with the school yard mine is longer than yours competition.
or
BobMic something is wrong and the tranny guy should be able to fix it!!!
Just got off the phone with Monster transmissions and they said the tv line pressure wont allow it to go into OD and I need to pump the gas pedal at a lower speed which sucks for me. He said, theres WOT 3-4 up shift kit from B&M # 70249 that would correct the problem. Im going to let this go until winter. Dumped to much into it this year. Good thing is shouldnt need 4th gear at the 1/4 track.
Did this shop rebuild your tranny? The part that allows the transmission is the corvette servo, which I believe keeps the line pressure high enough to allow shift into 4th at WOT. So, adjusting the TV cable will do this, but your tranny will fry. Your TV cable needs to be set to maintain transmission pressure, perios, not for WOT use. The Corvette servo does this, and the transmission shop should have known this, and if they rebuilt your transmission should have put corvette parts in it. IMHO.
Oh ok mate, so you are the good guy now? It wasnt you that suggested the trans!!!
We agree on something. It certainly wasn't me that suggested the transmission. I never suggested that I was. I initially answered a question of rear end ratio. The response came back, "I dont remember having high speed issues with stock tranny, but I did use that 3200 stall once I got the car.", plus other posts by bobmic93 that would lead one to believe that the opening post had little to do with the problem. I see you are still unwilling to make any contribution to bobmic93, which means you continue not to be a part of the solution, and by your own words, that makes you the problem.
Monster Transmissions doesn't know as much about these transmissions as you would hope. "Pump the gas pedal at a lower speed" so it will shift to OD(?) later(?). He may as well spin around three times while he clicks the heels of his ruby red slippers together and chants, "There's no place like home." The B&M part he refers to is a standard feature of a CORVETTE(only) 700R4. I'd bet big money that the part in the B&M kit is a stock GM part, and not some special, aftermarket doodad.
More bad info here. The servo(s) and the TV valve, have nothing, directly, to do with one another or 4th gear engagement at WOT. The item, apparently, missing in bobmic93's transmission, is the 3-4 shift valve sleeve, that installs in the valve body and is exclusive to Corvettes (and B&M?). My understanding of these transmissions is rudimentary, at best. We need Pete K. to explain it properly.
RACE ON!!!
For once I agree with CFI EFI, you should PM Pete K and see if he can shed light on your problem.
As for CFI-EFI, it's sadly par for the course... great wealth of knowledge, tempered only by zero patience for those he feels are inferior...
Speak for yourself, Bubba. You are putting words into my mouth, not uttered by me. If YOU think he is inferior, say so. Don't say that *I* did, when I didn't or tell me and others what *I* feel. You are on the ragged edge...
Originally Posted by bogus
tragic, really. It gets old when just about every thread he gets involved with decends into name calling and pissing contests.
And do see me doing any name calling? You had better check before you spout off as you did above. Notice, too, that the biggest problems are caused by those that have nothing to contribute to the subject of the thread. I would call that rebel rousing.
I bought the tranny from Monster out of Florida and had a local tranny shop put it in.
RACE ON!!!
Thats correct according to Monster. They said the valve body has to come out and that part inserted and your done.
Probably been discussed by now, but easiest thing to try is to put it in 3rd, wind it up to about 120mph which should be around 6000rpms, then let off WOT but keep 1/2 throttle down, and shift to OD. See if it shifts to 4th gear at that throttle. If it does, then you are just missing the WOT corvette servo or whatever, BUT your car should still be accelerating.
With my '92 and 3.45 gears in now, I spin to about 5400-5500 before it shifts from 3rd to OD at about 125mph, and the car still pulls nice and strong at WOT.
RACE ON!!!
I am not going to decend into another pissing contest with you.
For some unknown reason, you can go out here, be all attitude, and when people call you on it, blame them for it.
If you can't see it, then so be it... just check the attitude at the door.
oh, and who ID'd this as a transmission problem in the first place?
You'd best "check" saying I said or think, things that never occurred to me. Are you allowing your feels to seep out, and then blame them on me?
It certainly wasn't me. I followed along with the question, as asked, believing it was a rear end ratio situation, like the open post intimated. I denied bringing up the transmission as an issue yesterday (4/27/06) in my post at 6:01 PM (MDT). I know you first asked what trans the car had. I don't care enough to go back 3 pages to check who it actually was. I know, and I never claimed it was me. Wazza matter? Can't you keep up?
And yet another useless member of the peanut galley, with no thought on the subject, chimes on. I have to admit, however, if there is anyone that would be familiar with "A DOUCHE", it would be redbullapril23. You might heed the words of your mentor, Casethecorvetteman, who said:
Originally Posted by Casethecorvetteman
If youre not part of the solution, youre part of the problem.
Since YOU have not uttered one word on the topic, HE has done you the favor of labeling you.
Did he give any reason for pumping you full of the hot air about TV pressure and pumping the pedal? I'd be leery of someone that tries to slide by with a fantasy explanation like that.
And yet another useless member of the peanut galley, with no thought on the subject, chimes on. I have to admit, however, if there is anyone that would be familiar with "A DOUCHE", it would be redbullapril23. You might heed the words of your mentor, Casethecorvetteman, who said:Since YOU have not uttered one word on the topic, HE has done you the favor of labeling you.
RACE ON!!!
actually i suck dick for a living so i guess u could call me a ***** and close to a girl well actually im half and half. what ne? first ride is free but wait u must be longer than 2 inches to ride ... guess u dont qualify..
u have no expirence except u say... im an old time mechanic. which means i worked on cars under my shade tree and i am to ****in stupid to know what a computer does. congrats! u always jump down ppls throats and give gay *** scarcastic answers... its usless bull**** that be littles someone.. not everyone is as "qualified" as you.
u dont ahve an lt1 or an l98 u have a pos car that runs pos times and act like u know everything just from readin adn commentin on what everyone says. do ur self and all of us a favor ****in shut the **** up!
dont ****in breakj u hip tryin to walk to the library to use the internet u ****in old geezer.
this site is to help ppl not to criticize them u ****in jerkoff.
say what u will to me call me gay idk i jerk off with sand paper i dont pull out i suck dick for $ dont matter to me.... just ****in die!
wait im sorry u feel the need to talk **** so much its becuase the **** falls right out of that loose ******* of ures u ****in ******. i feel sorry for ure man since u say right there that u are part of the 13 seond club
