Timing Chain question for LT4
Old Apr 27, 2006 | 08:34 AM
Achilleus07's Avatar
Achilleus07
Default Timing Chain question for LT4
So im needing to get a new timing chain for my Hot Cam install coming hopefully next week. I have had people telling me to get the GM Heavy Duty chain which I was going to do....but I have to ask...what about the Cloyes Double Roller chain? Will there be a difference performance-wise between the two? Im looking for any hp I can. What do you guys think?
Old Apr 27, 2006 | 10:25 AM
96GS#007's Avatar
96GS#007
If you get the double roller you'll need to switch to an electric water pump and program out the crankshaft position sensor.
Old Apr 27, 2006 | 10:39 AM
Achilleus07
Im already switching to a Meziere, putting on Long tubes and adding a Hot cam. Just wondering if one chain will be better than the other or if it doesnt really matter.
Old Apr 27, 2006 | 10:44 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
If you are switching to the Meziere then the Cloyes is the way to go. I would recommened the cloyes 3145 from Summit. Good timing chain for a good deal. Its the one I run.
You will need some slightly slimmer cam retention plate bolts. Any speed shop will have some and they are about .50 cents.
Old Apr 27, 2006 | 10:51 AM
Achilleus07
Does it make a performance difference than the GM heavy chain? And thanks for the Summit number...always makes it easier
Old Apr 27, 2006 | 10:56 AM
VR'92's Avatar
VR'92
St. Jude Donor '03
Well the GM chain is made to work with the regular water pump. This also make it about $200+ bucks. The cloyes chain is a true double roller which costs about $70- bucks.
Probably not much of a performance benifit on either here. You'd just want these parts to be strong.
Old Apr 27, 2006 | 10:58 AM
Achilleus07
K...I just didnt want to lose anything from one over the other. And lets see $200 difference...yeahhhh double roller it is. I really appreciate it as always.
Old Apr 27, 2006 | 11:18 AM
VR'92's Avatar
VR'92
St. Jude Donor '03
Old Apr 27, 2006 | 12:29 PM
sothpaw2's Avatar
sothpaw2
Good choice--go electric if you are changing the timing chain. The GM chain comes with a bad gear which hurts your motor if you happen to get a bad GM waterpump.
To Timing Chain question for LT4
