Ran the scanner again today-no codes
BLMs under idle 112 with a little throttle 128
TPS .49-good
MAT 92-93, have to look up
MAY 7.27 Grams-have to look up
MAF raw input 7-have to look up
Load variables (lV8) 50 same as above
IAC 106 steps-on startup
Knock Count 13-!!!!
MAP.94-on start up
AFR 15.31
Well, since I'm new to this-I've got alot to learn.
All digi displays are very close to scanner.
Your thoughts?? Thanks Guys. Hey, Ray, haven't ventured into anything else yet
but sooner or later I'll get there, just getting comfy.
one step at a time.
Your BLM's at idle are rich and close to a Code 45 territory if they stay there with some throttle - less than another half volt from the TPS, speaking of which, you might try bumping it up to .54 or .56. Is the throttle body squeaky clean? Low TPS, dirty throttle body, misadjusted minimum air can sometimes produce a 34 and richen it up.
13 knock counts isn't so bad as long as you aren't pulling lots of timing.
MAT looks ok, especially if it wasn't that hot outside.
don't know what the MAP on start up is...you don't have a MAP sensor
MAF Raw is kind of meaningless, stick to the Gms/sec, that has meaning.
LV8 is engine load, that info is used along with vehicle speed, throttle position, coolant temp, MAF flow, etc, all to set up proper fueling.
Actually I think it fluctuated .49-.51 thanks again.
