Check Engine Code 53
Old Apr 28, 2006 | 06:25 AM
Gregory VanLare's Avatar
Gregory VanLare
Default Check Engine Code 53
I have a code 53 high voltage. I ran the car over to the auto store and they put there meter on it and the voltage looks fine! They did say the amperage was all over the page though. I have an 85, does this mean I need to replace the alternator?
Old Apr 28, 2006 | 07:45 AM
rick lambert's Avatar
rick lambert
Make sure all your cables and connections are good,and belt is tight.
They should or you should be able to measure the volts while running, around 14.
