How much for a good 4 bolt main block?
Old Aug 21, 2001 | 07:58 PM
Corey_68's Avatar
Corey_68
Default How much for a good 4 bolt main block?
I need to purchashe one. What is the going rate for one?
Old Aug 21, 2001 | 09:12 PM
Corey_68's Avatar
Corey_68
Default Re: How much for a good 4 bolt main block? (Thad)
Come on guys, I KNOW several of you are running 4-bolt main 350's.
Old Aug 21, 2001 | 09:37 PM
FoolCrzy's Avatar
FoolCrzy
I got the GM ZZ4 Short Block. $1889.00 4-bolt, Forged crank, New rods and pistons ready to go. That's one option.
Bought mine from http://WWW.JEGS.COM
Old Aug 22, 2001 | 12:12 AM
mikey's Avatar
mikey
what do you want/need? lt1 4 bolt block or l98 or what? or are you just building a carbed 350 or something..
used lt1 blocks seem to fetch $600 pretty easy, but i'm sure that price could go up or down depending where you look..
Old Aug 22, 2001 | 01:53 AM
ChrisB's Avatar
ChrisB
Default Re: How much for a good 4 bolt main block? (mikey)
A normal LT1 block should be around 350 bucks (here in Texas anyway). 4 bolt's were in the vette's, caprice's, and crate motors.
A 2 bolt block with splayed maincaps is stronger and better up to a 4.06 bore. If you are going to try and get fancy with it (bore relocation, etc) it has been suggested that then a 4 bolt block is a better choice (4.09 bore, etc.) though I wouldn't really recommend that.
Old Aug 22, 2001 | 04:50 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Email 4deatr, he has one I believe, a whole engine for that matter. He is here in the C4 parts for sail section. Email and see what he can do for you. Steve
To How much for a good 4 bolt main block?
