ZF6 locked in reverse
Old Apr 28, 2006 | 06:24 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Default ZF6 locked in reverse
It seems that perhaps I've read here that this is a fairly common problem, but I had no luck with the search. Is this a definite tear-down or is there something I should look for first. BTW, I'm experienced on manual rebuilds of many types and once rebuilt a ZF 5-speed in another type of vehicle, having none of the special tools. It took a while longer than it could have but I got it done with no problems. Thanks.
Old Apr 28, 2006 | 06:50 PM
bogus's Avatar
bogus
damn...
the first thing I would be sure of is that the lockout lever or the shifter frame isn't broken or jammed.
There is a frame that supports the shifter, it's made of pig metal and is prone to breaking.
You have to get the console and such off anyway, just seems to make sense to me to be sure it's not the problem before dropping the transmission.
As for working on these boxes, I would pass. They require jigs to support the gear sets and such. Some of the gears require heating, and the recieving shaft, freezing, to make them fit properly.
Those are the things I know...
Contact www.zfdoc.com for a quote.
Old Apr 28, 2006 | 07:02 PM
mudslide's Avatar
mudslide
I can do the old muncies with my eyes closed and some auto trans but when I took out my six speed and read up on taking it apart --I dont think so. they dont even have a cover to look in there to check it out. Its like the new electronic automatics --leave it to the pros. There isnt even a linkage to knock out of place like the old ones that used to get stuck in reverse. check what bogus said then call the doc like I did --He is very helpfull --emailed me every day about my problem
Old Apr 28, 2006 | 07:33 PM
Corvette Kid
Originally Posted by bogus
damn...
Well this transmission's already out. It was dropped off at my house. Heating and freezing is no problem. I have to do things like that all of the time at work on various components. As far as the holding fixtures and such, the other ZF I built called out for all of that stuff and a bunch of other special tools I didn't have either, but I improvised. I'm not afraid of these things, I just want to make sure I don't start a complete teardown if it's not necessary. I've built 3,4,5,6,7,8,10 and 13 speed transmissions, so I'm not intimidated by it. You haven't lived until you've built twin countershaft trannys with a back box that also has twin countershafts where the gears also have to be in time or they'll lock up.
Old Apr 28, 2006 | 08:50 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Keep us updated if you tear into it.
I'd guess at worse, you'll need to do a jig or to for disassembling the mainshaft in a press, since a puller might not be capable of it. It's not like it was built by ancient druids.
I did my 4+3 without any special tools, with the exception of the input shaft bearing. I'm gonna rebuild it again though because the 1st gear shim is too big. The design of the ZF is pretty much the same, just more parts. Reverse gear is probably harder to get to.
Old Apr 28, 2006 | 09:18 PM
Strick's Avatar
Strick
Hi Chris,
A six speed? For your C4? Are we making the swap?
Old Apr 29, 2006 | 08:16 AM
Corvette Kid
Originally Posted by Strick
Hi Chris,
No, I'm too lazy to shift all of the time. Besides, I like blowing by you wannabe power shifters while you're looking for the next gear and abusing your powertrain....
Old Apr 30, 2006 | 02:40 PM
Corvette Kid
I will. The good thing is that a lot of the truck transmissions I work on at times are also end-loaders like the ZF. They are different indeed but are also easier in some respects, more difficult in others. Obviously every tranny is different but the wide variety of manuals I've worked on over the years has given me the experience and confidence to tackle any. Even though I work in a well equipped truck shop, there is no way anyone can have every special tool for the variety of trannys and engines that we work on. A very few are absolutely essential at times but improvisation is the name of the game in all aspects of automotive repair.
To ZF6 locked in reverse
