Need New engine. Options?
Old Apr 28, 2006 | 11:52 PM
jakers's Avatar
jakers
St. Jude Donor '06
Default Need New engine. Options?
Has anyone replaced an engine?
I believe I spun a bearing and damaged the engine. I am considering starting from scratch with a crate engine or Jasper remanufactured engine.
I am interested in hearing your experiences and the costs.
Thanks!
Old Apr 29, 2006 | 12:02 AM
BlownV6's Avatar
BlownV6
Thanks!
Forged LT1 Rebuild and add a blower
Old Apr 29, 2006 | 03:59 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
http://www.golenengineservice.com/sp...l/lt1_lt4.html
http://www.strokerkits.com/?source=bookmark
http://www.strokermotor.com/
http://www.larrysperformance.com/data/short.html
http://www.araoengineering.com/
Old Apr 29, 2006 | 04:40 AM
robertt43's Avatar
robertt43
Thanks!
GM crate motor........Save your old block......I've seen new 350 short blk,195 hp for $1105,[factory 84 was 205hp], and 550 hp as high as $6000.....The only way to fly.......Cost is determined by how fast you want to go........Summit has a ton of them advertised,some with FREE shipping
Old Apr 29, 2006 | 07:11 AM
larryfs's Avatar
larryfs
how long after your hot cam install did the bearing spin ???
(seems to be a common occurance)
Old Apr 29, 2006 | 03:38 PM
jakers's Avatar
jakers
St. Jude Donor '06
Default Not long
Not long, maybe 5k?
Old May 3, 2006 | 07:52 AM
jakers's Avatar
jakers
St. Jude Donor '06
Default Jasper?
Anyone use them?
Old May 3, 2006 | 08:10 AM
CorvAdel's Avatar
CorvAdel
Pardon my ignorance, but which bearing spun...cam bearing..?
95NOSvette's Avatar
95NOSvette
www.victoryracingengines.com several guys I know have had very good things to say about them......Golen engine builders , like was mentioned earlier, is also a very good reputable builder......Either way, do yourself a favor and get something "higher" quality than what you had or you'll "very" likely end up in the same position......and IMO, not just a remanufactured job, they slap 'em together like you wouldn't believe.
Old May 4, 2006 | 09:40 AM
victoryracing's Avatar
victoryracing
Thanks for the recommendation.
Old May 4, 2006 | 09:45 AM
bogus's Avatar
bogus
if you are on a budget, a used LT1 from a Camaro can be quite affordable...
Old May 4, 2006 | 03:00 PM
bacardioil's Avatar
bacardioil
I just had a lt4 s/c 383 done by Port Pros in Tx. very nice work. service wise, we had a problem with head studs leaking, Harold the owner of Port Pros came up from Tx. to Pa. himself to make sure the problem was fixed. thats service and a stand behind his product. I dont know of to many companies that would do that. PortPros.com
regards
Old May 4, 2006 | 06:27 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Anyone use them?
See my post re/ Jasper in your last thread on this very same subject. Click
Old May 5, 2006 | 09:47 AM
jakers's Avatar
jakers
St. Jude Donor '06
Default Thanks!
Thanks Chris,
I have ruled out Jasper and the other remanufactured engine guys! That would work if I was selling the car but it looks like it is a keeper now because I am buried in the car and even with the rebuild it is not worth much...
I have a few great options. I have a local guy who builds race engines locally and has rebuilt quite a few LT engines. I plan to go with all forged components and come out with a stong strong balance and forged 350. I would love to get a 383 but that may be stretching a bit right now.
Old May 5, 2006 | 03:29 PM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
I just pulled mine and rebuilt it, bored it, ported it, added better internals, etc... spent under $1500 for the entire project, including all aftermarket performance parts. That includes all the machine shop labor, and all the extra crap I bought at Vatozone when i found i was missing stuff here and there.
Old May 5, 2006 | 04:56 PM
fusionr's Avatar
fusionr
buying a new engine all depends on your budget. Any corvette lover will tell you the ideal vette engine is a 427 that might be a tight fit but if you can get it in it would be well worth it. Plus a good one will run you about $7,000 the performance is well worth it because remember later on if you want more horsepower you can still upgrade with a supercharger.
[IMG]www.spunoutonline.com[/IMG]
Old May 5, 2006 | 05:27 PM
Corvette Kid
Thanks Chris,
If you're building all forged anyway, there should be virtually no difference between in price between building a 350 (or 355) or a 383. You could also build a 388 like I did and achieve zero deck w/o any block shaving.
Old May 6, 2006 | 10:28 AM
TOO_HOTTVETTE's Avatar
TOO_HOTTVETTE
how did you do it so cheap? did you do it yourself?
To Need New engine. Options?
