ABS Warning light comes on after shift ??!!!
Old Apr 29, 2006 | 09:01 PM
Roadster89's Avatar
Roadster89
Default ABS Warning light comes on after shift ??!!!
Just had my auto tranny rebuilt, no doubt they did a nice job. The shifts are firm, breaking the wheels nicely during 1-2, at which point the Anti lock warning comes on and stays latched until I cycle the ignition (turn off and restart car). As it would normally, after I start the car and initially drive, the ABS pretest works fine. Under hard breaking the system pulses perfectly, car stops nice and straight. During normal driving and even mild shifting, no problems, but right after a full power shift, the light comes back on. Any thoughts?
Old Apr 30, 2006 | 10:39 AM
Tom Piper's Avatar
Tom Piper
No guarantees, but top off your brake fluid and try it again -- make sure it is to the line at the top of the master cylinder.
Tom Piper
Old May 1, 2006 | 02:06 AM
Roadster89's Avatar
Roadster89
Interesting thought... though its not the red Brake warning message light, but the bottom right Anti Lock indicator that illuminates. Why do you think the fluid level would effect it ?
Old May 1, 2006 | 03:02 AM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
Either the low brake fluid idea or the ABS DIC light relay has a loose connection.
Old May 1, 2006 | 06:41 AM
Tom Piper's Avatar
Tom Piper
Several, including myself, have had this problem.
And, topping off the brake fluid solved it for me.
Tom Piper
To ABS Warning light comes on after shift ??!!!
