Bosch MAF Sensor -- What do the guts look like?
Old Apr 30, 2006 | 09:30 PM
Rich Silvestris's Avatar
Rich Silvestris
St. Jude Donor '05
Default Bosch MAF Sensor -- What do the guts look like?
I've been chasing a nasty Code 33:
MAF and Burn-off relays replaced. IAC and Throttle body cleaned. Scan showed O2 and Coolant Temp Sensors out of range, so they got replaced. Seafoamed the motor, including the intake.
The code does not always show. About half the time the car runs like a top. The other half of the time it stalls when I first start it; then I'm in for the SES, and a rough on/off throttle response for the entire ride.
The intermittent nature of this makes me think the wiring is funky; especially since morning cold starts seem to avoid the code. It is a good bet, though, that if I pull over and shut down the motor and restart it, that it will stall and the code will set. I have yet to probe the harness. It's not my favorite job, but it is on my to do list.
Meanwhile, I have been shopping for MAF's on the web, and one that I saw had wires running through it like a light bulb's innards. The Bosch unit in my car does not have any thin wires running across the insides. Can anyone tell me if it should?
Better yet, can anyone tell me WTF is going on??
Old Apr 30, 2006 | 09:35 PM
_twisted_'s Avatar
_twisted_
Are you saying you pryed the cover off of the electronics side of the MAF?
If you didnt, the seal on mine was missing over 50% of it, the cover came off easy when I removed the remaing sealant - inside was a bunch of what looked like condensate corrosion. The guts look like a circuit board with a bunch of solder
I shot contact cleaner in there hit it with a hair dryer and resealed it - then I cleaned up the connections to the weather pack connector.
Intermittent troubles suck, G/L
Old Apr 30, 2006 | 09:42 PM
Rich Silvestris
St. Jude Donor '05
I haven't opened the electronics enclosure. I'm just talking about the view through the sensor into the throttle body. The sealant is mostly still on the electronics enclosure, but thanks for the heads-up.
Old Apr 30, 2006 | 09:44 PM
RRT vette's Avatar
RRT vette
Take a look at the wires in the MAF sometimes they get a foreign object in there and cause this type of problem. Just need spraying with contact cleaner if so. Need to troubleshoot the MAF since you replaced the power and burnoff sensors. Wiring might not be the problem. The troubleshooting diagram is in the FSM and if you don't have one.... pm Agent86, he's got a scan of one.
Old Apr 30, 2006 | 09:54 PM
vader86's Avatar
vader86
Probably the MAF itself. Expensive replacement.
Do not buy the aftermarket 'performance' sensors, stick with GM.
Old Apr 30, 2006 | 10:03 PM
Rich Silvestris
St. Jude Donor '05
RRT: I have the FSM, and I know I will be out there with the VOM soon.
Vader86: I just read your webpage instructions on the IAC. I didn't take mine apart, and I didn't push it in all the way before installing it either. I left it in the same position it was in when I removed it. Is that okay?
Old May 1, 2006 | 09:21 AM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
I was told the same thing when I had mine replaced.
Old May 1, 2006 | 09:48 AM
vader86's Avatar
vader86
should be fine
Old May 1, 2006 | 10:10 AM
rick lambert's Avatar
rick lambert
One thing you should do is reset the IAC. I think Vader may have a write up on his site. Pretty simple, but you may need to adjust your minimum airflow setting-then you may need to adjust the TPS voltage. If not, post, and either I or another member will walk you through it. I'm really dumb when it comes to posting pics. Gotta get my kid to help me when she comes back over again.
Well-looks like Vader says it should be fine.
I wouldn't be so quick to condem the MAF-it very well could be, but it's not cheap and there's quite a few things that should be thourghly checked first.
Old May 1, 2006 | 10:47 AM
RRT vette's Avatar
RRT vette
A bad IAC does not show a code. I consider this to be a mainanence item. You car stalling at start up this could be the IAC. You stated you cleaned the IAC and TB. Did you take the IAC out of the TB for cleaning and follow the proper steps? As for the intermittant code 33 You have a volt meter and FSM so just follow the steps. Once the code is fixed this will rule out the MAF and give a more narrow guide to fix any other problems. I'd fix the code first. IMO
To Bosch MAF Sensor -- What do the guts look like?
