Castrol GTX
Old Apr 30, 2006 | 10:53 PM
robs87vette's Avatar
robs87vette
Default Castrol GTX
I was told castrol was developed for 4 cylinder cars and should not be ran in my vette. Any truth in that? Or rather do I need to switch oils?
Old Apr 30, 2006 | 10:56 PM
BlownV6's Avatar
BlownV6
Why are you running anything other then Mobil 1?
Old Apr 30, 2006 | 10:58 PM
robs87vette
why Mobil 1? Is that synthetic?
Old Apr 30, 2006 | 11:06 PM
eguyett1985's Avatar
eguyett1985
I've never had a problem with Castrol. I run it (10w-40) in my new 408 and haven't had any breakdown issues. It depends on how many miles you have on your engine though, Mobil 1 is so good you probably shouldn't run it for 1-2k miles so your rings can seat in first. Break your engine in on conventional oil then switch over to M1.
Old Apr 30, 2006 | 11:11 PM
robs87vette
Good info, I have 0 miles on my engine so far. Hopefully tomorrow!!
Old Apr 30, 2006 | 11:42 PM
NitrousSam's Avatar
NitrousSam
There are other options other than Mobil 1. Royal Purple and Amsoil are both amazing oils. I personally use Royal Purple in my higher horsepower engines and their oil works. I am not telling you to switch but be aware there are other options beyond mobil 1.
vader86's Avatar
vader86
Nothing wrong with using GTX in your engine.
Old Apr 30, 2006 | 11:55 PM
Red Tornado's Avatar
Red Tornado
I broke my engine in on the Castrol GTX dino stuff. 5w-30.
And I will continue to use it for the life of the engine.
Old May 1, 2006 | 12:00 AM
bogus's Avatar
bogus
Rob,
Use the Castrol. It is not going to hurt anything.
You are building a new engine and you need dino oil to aid in break in.
Once you get about 6000 miles on it, then switch over to Mobil 1.
As for Castrol being "designed for 4 cylinders," that does not exclude it for a V8. It just means that is capible of dealing with the stresses inside a 4 cylinder.
Old May 1, 2006 | 12:03 AM
bogus's Avatar
bogus
With your engine, I would switch to Mobil 1.
Unless you have an external oil cooler with the additional volume that comes with, I would switch over to Mobil 1. The thermal advantages are just beyond words... and with the heat issues within a C4 are so serious... damn...
It would be worth it...
Old May 1, 2006 | 12:13 AM
robs87vette
I may after about 4 or 5k miles, I guess I'll cross that bridge when I get there. Thanks for all the info, I figured Castrol was a good choice for break-in!
Old May 1, 2006 | 12:22 AM
Red Tornado
i do have a factory oil cooler at least. the oil temp maxes out at 210-220* on a hot day. i have a 180 t-sta and fans reprogrammed accordingly.
Old May 1, 2006 | 09:07 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I have used Castrol Syntec when I couldn't find M1 in the five-gallon convenience size jugs. It's meet GM's specs and I've never had a problem.
Old May 1, 2006 | 12:43 PM
bogus's Avatar
bogus
Yes, perfect!!!
Old May 1, 2006 | 12:45 PM
bogus's Avatar
bogus
That's not too bad, but for dino oil, it ain't good.
What is synthetic oil? It's conventional dino oil with the various waxes removed and friction modifiers added. Those waxes are what build up causing sludge. Sludge stops oil flow and does bad things to the inside of a motor.
bogus's Avatar
bogus
Syntec is as good as any synthetic on the market... GTX isn't a synthetic, tho.
Old May 1, 2006 | 11:43 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
I believe your owner's manual specifies an oil meeting GM Standard 4178M. I've never seen a non-synthetic meet this standard, but several synthetics meet it.
That said, in this AMSOIL commissioned comparative motor oil test of Nov 05 the Castrol GTX actually performed pretty well for a non-synthetic:
Comparative Motor Oil Test
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
To Castrol GTX
Old May 1, 2006 | 11:46 PM
bogus's Avatar
bogus
the rub is that we should not use synthetics for break in... the rings would never set.
back in 1955, Chevy had a problem with the rings... the engines were sucking in more oil than gas, I think!
The fix? run some bon-ami into the carb whilst the engine was running! That set the rings!
This is also back before an oil filter was STANDARD.
Old May 2, 2006 | 12:13 AM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
Chevy has been using Mobil 1 as the factory fill since 1992. With the new LT1 engine, the engineers removed the oil cooler because of the reverse flow cooling system and the use of Mobil 1 synthetic oil.
My question is this: If synthetic is used at the factory, how did my rings seat on my 92, 94 and 96 Vette?
Old May 2, 2006 | 01:13 AM
vader86's Avatar
vader86
M1 was instituted with the deletion of the oil cooler and the Gen II SBC has much tighter build tolerances, thats how it gets away with using M1 from the factory.
