pros and cons on removing front cats
Old May 1, 2006 | 10:29 PM
vettefamily's Avatar
vettefamily
Default pros and cons on removing front cats
I'm about to install Magnaflow cat back system with a high flow cat. Is there much of an advantage in removing the front 2 cats on my 1990 Vette? Will it make the exhaust that much louder? Any help will be greatly appreciated.
Mark
Old May 1, 2006 | 11:44 PM
bogus's Avatar
bogus
it will gain noise... it might also pop a little... but it won't effect emissions at all... and will add power.
I would loose them.
Old May 2, 2006 | 02:45 AM
raisinbran's Avatar
raisinbran
Do a search on removing the precats. you can also check out vader86's website. but basically you will be fine without them, especially if you get a 3-stage cat.
Old May 2, 2006 | 04:03 AM
vettefamily
vader's 86 website is very informative, thanks.
Mark
Old May 2, 2006 | 03:46 PM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
Mine are both empty (main cat is hollow too), but still in place. I get a raspier sound with popping. I like it though
Old May 2, 2006 | 04:34 PM
NT Vettman's Avatar
NT Vettman
Got rid of them on my 90 and installed a high flow cat and it woke the car right up. I also did a 52 mm throtle body with it. It also got a little louder. It was well worth it. If you do it, buy the 2 1/2" diameter pipes not the 2 1/4. Got mine from Mid America.
To pros and cons on removing front cats
