Transmission Cooler
Old Aug 22, 2001 | 11:11 AM
codyusa's Avatar
codyusa
CI 5-6-7-8-9-10 Veteran
Default Transmission Cooler
I am going to put a vigilante converter on my '87. i was worried about the heat buildup. What type of transmission coolers are recommended? Will any type/brand suffice? Thanks
Old Aug 22, 2001 | 03:50 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: Transmission Cooler (codyusa)
I put in a Hayden rated for 26000 gvw. It is not sufficient for road racing or lots of hard street driving. I now have the largest B&M cooler sitting on my work bench waiting to be installed. They don't rate it but it says, "for racing only" so it must be the one I want. You should consider putting in a temp guage to monitor your tranny temp. I have an Autometer unit. To mount the sender I got a B&M tranny fluid drain kit and mounted that in the tranny pan. The adapter for the temp sender threads right into that. It works slick. I hung the guage on the front lip of the dash in front of the left vent in the center console. With the Hayden unit I have now my temps go to about 240 aftetr several laps on a 3 mile road coarse, Brainerd Int. Raceway. The Hayden cooler is the one hanging in the back of the picture, waiting to be mounted. The B&M unit is a plate type cooler, similar to my oil cooler which you can see in this picture. I say, "get the biggest cooler possible!" Good luck.
Old Aug 22, 2001 | 06:31 PM
jpee's Avatar
jpee
I have a 9" Vigilante 2800 converter in my car, but I never road race with it.. I added a B&M small 18" x8 (approx) cooler in front of my power steering cooler.. it is running in tandem with the factory cooler..
My 96 has a trans temp gauge, & in heavy traffic my trans temp goes to 220.. & I'm babying it..
If I'm driving over 50 mph & the converter is locked my trans temp is 190 no matter how hot is outside..
When I drag race it its no prob because I has 20 min between rounds to let it cool...
Old Aug 22, 2001 | 08:18 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
A trans cooler is reguired with a high stall convertor
Old Aug 23, 2001 | 12:27 AM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: Transmission Cooler (tntcorvette)
Hay Tnt, how is the B&M cooler working for you. That's the one I just got and havn't put in yet. Do you have a temp guage on your tranny, what kind of temps do you see, do you road race??? Thanks.
To Transmission Cooler
