91 Heater kicked on while in A/C mode ???
Old May 3, 2006 | 02:43 PM
mjones's Avatar
mjones
Default 91 Heater kicked on while in A/C mode ???
Year is a 91. I was out cruising this morning and had the A/C on and all of a sudden hot air is shooting out of the vents. Turned off the A/C and then turned it back on and it was back to normal. This has happened before over a year ago a few times. My dad has had this happen to his C 4 also. Any thoughts??
Old May 3, 2006 | 04:03 PM
adelii's Avatar
adelii
Check your A/C clutch for slippage. Use the smell test. It should smell burnt. I had this happen to me as well. It occurred on and off until the compressor locked up. I recently had to overhaul the system, new compressor, clutch assembly, drier, in line filter, pressure valve and a system flush before recharging the system. You may get away with changing the clutch assembly. Good luck.
Old May 3, 2006 | 04:47 PM
mjones's Avatar
mjones
Okay thanks.
To 91 Heater kicked on while in A/C mode ???
