Scratches up and down drivers window...Help
Old May 3, 2006 | 03:45 PM
9vette4's Avatar
9vette4
Default Scratches up and down drivers window...Help
'94 vette coupe. Drivers side window getting scratches up and down the window. Are there pads in there or something and how can i fix this? Is it a tough job to do. Rick
Old May 3, 2006 | 03:58 PM
Rich Silvestris's Avatar
Rich Silvestris
St. Jude Donor '05
Are the scratches on the inside or the outside of the window? There are anti-rattle pads on the inside. On the outside the only part that is supposed to come in contact is the seal at the top of the door. On my 87, one of the new outside seals had a ridge pushing through the contact pad, and it scratched the window. It took a while to find out what was doing it. If you take off the inside door panel and poke around with a flashlight, etc., you are bound to find your problem.
Old May 3, 2006 | 04:04 PM
9vette4's Avatar
9vette4
the scratches are on the outside. i just noticed them the oter day and ran my fingers over the scratch and it is in the glass.....
Old May 3, 2006 | 04:53 PM
ALLT4's Avatar
ALLT4
Yes, there are pads inside there. I had the same thing with my windows when I bought my car. I believe it's cause when the outer seal that runs the length of the window deteriorates and lets debris fall down though the crack. Eventually something (dirt or other) will wind up finding it's way onto those pads and work it's way between the window and the pad. Then every time you run your window up and down it's just like taking something sharp and running it up and down the glass.
I bought new glass and anything inside the door that would contact the new glass including the pads, inner and outer seals. Unless you're really mechanically inclined I'd get help from a pro or someone who has done the job before, it's tedious work. Not to mention if you get new glass you WILL have to re-align the windows.
Here's a list with part numbers for everything I bought, mine's a 96 though. I imagine a 94 is the same. The first two part numbers are for window guides that you will usually find broken if dorks close you doors by pushing on the glass.
10243038 Guide, Door Window Channel, Right Hand,(Passenger Side), 1993-1996. GM Parts Direct
10243037 Guide, Door Side Window Channel, Left Hand,(Driver Side), 1993-1996. GM Parts Direct
10199731 Seal, Door Window Inner, Attaches To Door Panel, Left Hand,(Driver Side), 1990-1996. GM Parts Direct
10199732 Seal, Door Window Inner, Attaches To Door Panel, Right Hand,(Passenger Side), 1990-1996. GM Parts Direct
10245645 Seal, Door Outside Upper, Left Hand,(Driver Side), 1984-1996. GM Parts Direct
10245646 Seal, Door Outside Upper, Right Hand,(Passenger Side), 1984-1996. GM Parts Direct
EYY54691 Anti Rattle, Pad, Doors, 1968-1982, 1987-1996. Corvette America
ESG7030 Nut-Anchor, Door, Thread Size 8-18 Nylon, 1984-1996. Art's Corvette Parts
SGI180 Clip, Side Door Inside Handle, 1984-1996. Art's Corvette Parts
EYL48245 Retainer, Button, Push In, Black, 1994-1996. Art's Corvette Parts
Old May 3, 2006 | 05:16 PM
Bigredwing's Avatar
Bigredwing
Thanks for the thread Rick I meant to start one on this a while ago. My '94 has the exact same thing and my drivers window is loose too. Appreciate the info ALLT4.
Old May 4, 2006 | 12:31 PM
9vette4's Avatar
9vette4
Thanks guys.......all this info. is great. I like working on my vette ( nothing major though ) so i am going to take off the the door panel and see what's going on in there.Is there any way to get the scratches out? I may have caught it at the beginning so the scratches arent very noticable yet.
Thanks again ,,,, Rick
Old May 4, 2006 | 12:45 PM
rickneworleansla's Avatar
rickneworleansla
Have similar problem here.
Old May 4, 2006 | 12:51 PM
Bigredwing's Avatar
Bigredwing
Take some pictures of the process if you can! Sounds like you'll get to yours before I do.
Old May 4, 2006 | 02:01 PM
96corvetteLT4's Avatar
96corvetteLT4
Default Window Scratches
I had a similar problem with both windows on my '96. I pulled the door panel and found there is a plastic wire loom protector mounted at the outside rear view mirror that was rubbing just enough to scratch the glass over time. I was able to bend it out of the way, but figured it would only become a problem again later on, so I found some sheet foam at the craft store (my daughter's closet) about 1/8 inch thick that has adhesive on the back, cut to fit, done.
Old May 4, 2006 | 03:10 PM
bsmutz's Avatar
bsmutz
Use 00 steel wool and some rubbing compound to get scratches out of glass. DO NOT use it on your mirrors.
Old May 4, 2006 | 03:18 PM
9vette4's Avatar
9vette4
Thanks for the tips, i will try them......
Old May 4, 2006 | 06:51 PM
TestDriver's Avatar
TestDriver
Dude i was gonna start a thread like this also, my 95 has the same problem!! At least Im not the only one!!
Old May 4, 2006 | 08:09 PM
kopbet89c4's Avatar
kopbet89c4
I'd think the trim line does it. The rivets that hold it in place scratch it up.
To Scratches up and down drivers window...Help
