Brake Fluid
Old Aug 22, 2001 | 02:51 PM
dgoodhue's Avatar
dgoodhue
Default Brake Fluid
I am completely flushing my brake fluid how much do I need?
Is Ford brake fluid still recommended as a quality low cost brake fluid?
Old Aug 22, 2001 | 02:53 PM
scorp508's Avatar
scorp508
I used "Z Rated" fluid from Autozone on the advice from a local guy who placed 3rd at SCCA Autocross Nationals. They carry it behind the the counter, but available. So far so good.
I think I only needed one container, but buy two just in case. The lines are pretty darn small.
[Modified by scorp508, 1:53 PM 8/22/2001]
Old Aug 22, 2001 | 03:07 PM
89_FX3_6-spd's Avatar
89_FX3_6-spd
Default Brake Fluid
I just flushed flushing mine a few weeks ago and the fluid was nasty and dark, I used 1 quart of fluid and had a few small ones as extras in case I needed them.
I used Castrol "GTLMA" as I read up and that and ATE "Super Blue" appear to be the best for high perfomance street use. Others have a higher boiling points etc, but may absorb water (moisture) at a faster rate, when this happens the boiling point lowers and the fluid is then less effective, so for high-perf street use you want a fluid that has a good high boiling point and that keeps it longer, racers use fluids that have the highest boiling points but have to change the fluid quite often.
Old Aug 22, 2001 | 08:58 PM
White Lightning's Avatar
White Lightning
Default Re: Brake Fluid (dgoodhue)
I bought Ford fluid back in March, and it was considerably more costly than about a year ago (nearly doubled). It is no longer the low cost bargain it used to be. I've read that the Castrol fluid is very good.
-WL
Old Aug 23, 2001 | 12:20 AM
h rocks's Avatar
h rocks
Default Re: (scorp508)
Scorp, it's the same stuff. Ford/PFC "Z" Rated fluid. The Ford juice in the can *is* more expensive, and there's a few more ounces than in the plastic container.
Old Aug 23, 2001 | 01:09 AM
SPEEDEMON's Avatar
SPEEDEMON
FORD has a couple of different fluids. Does anyone know the part number of the one which everyone is talking about?
Old Aug 23, 2001 | 08:18 AM
urtoslo's Avatar
urtoslo
Default Re: (h rocks)
I've found that you have to shop around for prices on this fluid. Some dealerships charge 2-3 times what others charge. I still find the Ford high performance fluid (from the reasonable dealer) to be cheaper than the ATE...
Old Aug 27, 2001 | 10:58 AM
dgoodhue's Avatar
dgoodhue
The Autozone Natick doesn't carry it, they looked at me like I had 2 heads. He told me that I needed dot 5 brake fluid :smash:
I ended up going to the Natick Ford Dealership. They got a big chuckle when I told them it was for a Corvette and when I used my "GM Card" to pay for it.
To Brake Fluid
