flow chart for 87 ecm checking idle speed
Old Aug 22, 2001 | 03:00 PM
corveteer's Avatar
corveteer
Default flow chart for 87 ecm checking idle speed
i just replaced a jammed idle air controller. the idle speed would go slower
and slower every time i turned the car on. when it got to 500 i decided to
take out iac and look at it. my question is why was there never a trouble
code? doesn't the ecm monitor the idle speed?
stark@cameron.net
Old Aug 22, 2001 | 03:02 PM
scorp508's Avatar
scorp508
Default Re: flow chart for 87 ecm checking idle speed (chas stark)
Hmm.... I know that the ECM can store certain codes yet not display the check engine light. Did you jump it to see if any were stored?
Old Aug 22, 2001 | 03:19 PM
SunCr's Avatar
SunCr
There are no trouble codes for the IAC. The ECM commands the position of the IAC (number of counts) based on the desired idle speed programmed into the ECM and the actual idle speed of the engine.
To flow chart for 87 ecm checking idle speed
