I was thinking of changing my plugs on my 87. (75000Miles). I was wondering if they are all reachable by a novice or should i bring it in for my mechanic to do them ?
and I do it the same way. My 87 seems to love the ACDelco #41629, that's the new number compared to the old number in your owners manual. Mine also seems to run better at 8 degrees, rather than 6.
Oh hey, forgot to tell you, it's alot easier and safer (we have aluminum head so you won't cross thread)-use a short piece of rubber fuel line, place it on the end and use it to start the plugs, once you've got them started tighten them down snug and give them about a 1/2 to 1 turn-basically they require 14-15 pounds torque-but I'm bad and never use a torque wrench on plugs.
If it's any thing like my 90 pull off the inner fender wells on the passenger side. It make all the plugs more accessable, and it only adds about 15 minutes to the job and saves on knukle skin
I took out the whole AIR system, except for the pump. Also took out the EECS, less vacuum lines to worry about breaking off. Ever since then, removing spark plugs for inspection has been as easy as cheese. Not to mention a slightly cleaner engine bay. Weight-wise, the car is about 90% emissions control free.
I've heard mixed comments about the use of anti-sieze on plugs. One thing for sure, the plugs must be anodized. I used a cheap set of Champions in a car with aluminum heads once, and along with the bill for the heli-coil job afterward, I was offered that advice by the mechanic. Any of the quality plugs you've been recommended will qualify.
Don't forget the thread compound on the new plugs!
You will more than likely utter a few choice words before you're but it ain't nowhere near as difficult as replacing a heater core or a CDM tuner module!
