Opti Finally Died
Old May 4, 2006 | 10:41 PM
DG'sVette's Avatar
DG'sVette
Default Opti Finally Died
I know its been asked before but where does everyone stand tonight.
What brand do you suggest?
Where did you purchase?
Do you suggest just the cap & rotor or the whole distributer?
I'd like to get this ordered tonight & installed by the end of the weekend. I can start tearing into the car tonight. What fun??!!
Old May 5, 2006 | 03:49 AM
VenkmanP's Avatar
VenkmanP
Cap and rotor is false economy due to the high labor to replace it.
Since you have a vented opti, I'd just go with the stock replacement.
Old May 5, 2006 | 06:48 AM
Tom Piper's Avatar
Tom Piper
There have been some posts stating that the MSD Opti-Spark (not just a cap and rotor) has been released and in customer's hands.
I've not heard of the results of an install yet.
http://www.jegs.com/webapp/wcs/store...tegoryId=79317
Tom Piper
Old May 5, 2006 | 07:12 AM
RRT vette's Avatar
RRT vette
This would be a factory replacement piece IMO. ACDelco
Old May 5, 2006 | 09:11 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
And I believe you can get a GM Opti cheaper than $500 too.
Contact Chris May at Superior Chevrolet in Meriam,KS. 1-800-728-8267. Chris offers great discounts to Corvette Forum Members. http://www.superchevyperformance.com/
Old May 5, 2006 | 11:42 AM
SJW's Avatar
SJW
If you want the very best replacement unit you can buy that has a proven record in the field, the DynaSpark is the ticket.
If you feel like being a guinea pig for the new MSD unit -- and if it's actually available now -- go for it.
If you'd rather spend far less than the ~$600 that the DynaSpark would cost, go with a replacement OEM unit from Superior Chevy, and apply RTV to all housing seams prior to installing it.
The OEM Second-Gen Optis are pretty reliable, if they don't get doused with water or coolant.
The DynaSpark is nearly bulletproof unless you're going to rev it well above 6 grand, and is totally watertight (DynoTech encouraged me to hose mine down if I wanted to).
If you're gonna rev the engine way-high, the DynaSpark with the high-rev kit (no rotor) in combination with the Delteq DIS conversion setup is your best bet.
Be well,
SJW
Old May 5, 2006 | 12:00 PM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
Old May 5, 2006 | 01:49 PM
KCHOTBOAT's Avatar
KCHOTBOAT
That is great news. They are 10 min. away from me.
Old May 5, 2006 | 06:52 PM
CA Vette Chick's Avatar
CA Vette Chick
Hi!! New to the Board and Corvettes too. I had my C4 for less than a month when we had to replace this bad boy part. Chev wanted almost $700, and found that Summit Racing (800-230-3030) had the AC Delco part for $379 (back in January). Part #NAL-10457702
Hope this helps.
Old May 5, 2006 | 09:08 PM
TorchRedlt4man
NAL-1104032
Vented pin drive unit to fit your 95. Summit Racing has it for $289.88.
Old May 5, 2006 | 10:39 PM
RRT vette's Avatar
RRT vette
http://forums.corvetteforum.com/show....php?t=1382464
This might be a little cheaper than any.
To Opti Finally Died
