Volts read "sys" not 14.3
Old May 6, 2006 | 11:07 AM
USCG's Avatar
USCG
Default Volts read "sys" not 14.3
96 stock LT1 with no mods (electrical or otherwise). Garage Queen hasn't been driven in a month. Key-On/Engine-Off initial reading before startup was 12.1, and it started right up and ran fine. Volts immediately went to 14.6 +/- (Alternator charging).
After 20 minutes of driving, I noticed the volt reading settled down to 14.3, but would intermittently switch between 14.3 and "sys". Nothing in the handbook I could find. Before I drag out the Helm and spend an afternoon reading thru that, can anybody shed some light on this issue?
In keeping with another recent post, THANKS in advance! All help and positive comments are always appreciated, just not always acknowledged in the excitement of solving our various problems.
Old May 6, 2006 | 12:28 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
From owners manual.
In other words its vaguely telling you it could be several things. You should check and see if you have any CCM codes stored and go from there.
Old May 6, 2006 | 12:52 PM
Jerris's Avatar
Jerris
Pull the codes and we can go from there. Whenever the SYS light flasnes it means the CCM has stored an error code.
Old May 6, 2006 | 12:57 PM
USCG's Avatar
USCG
No codes, but my reader is giving me an "E". I pulled the TPS off just to check the reader, and it gave me the proper code. Reinstalled the TPS and again got the "E". I have misplaced my book that came with the code reader, so I can't look up what "E" is supposed to mean. Looks like this is gonna be a "Helm" day.
Old May 6, 2006 | 01:04 PM
bogus's Avatar
bogus
there are two code sources... the PCM and the CCM. You need to pull CCM codes...
Old May 6, 2006 | 01:08 PM
skateparkdave
You can jump pins 4 and 12 on your ALDL with a paper clip and turn your key forward (engine off) and it will display codes on dash.
Old May 6, 2006 | 01:26 PM
USCG's Avatar
USCG
I'm plugging my reader into the link just under the steering column. I assumed that would give me whatever codes I needed. Is there another place to pull codes? Do I need another type of reader?
Old May 6, 2006 | 01:33 PM
skateparkdave
Uhh hello! Read my post above. Your dash is a reader. The # will be the module. Example: #1 = ccm Then whatever if any code will follow.
Old May 6, 2006 | 01:38 PM
USCG's Avatar
USCG
Thanks, but forgive the slowness; I thought I had sold my last "paperclip" car years ago. Looks like the old paperclip still works on the 16 pin cars. Give this old fart some time to contort to the difficult positions needed to get the clip into the right pins and I'll be back with the results.
Old May 6, 2006 | 01:41 PM
froggy47's Avatar
froggy47
I tried a code reader one time & it only worked half/assed. Get another code reader or do it the "old fashioned way" as described above.
Old May 6, 2006 | 02:15 PM
USCG's Avatar
USCG
Seems like I wasted money on that code reader and need to put the paperclip back into the tool box!
Here's what I have:
1: H31-H33-H35-H37
9: H64
A: blank (no codes)
1.0: Blank (no codes)
One of my manuals indicates the H3x is the left & right rear wheel sensors (malfunction & continuity)
The H64 is the TPS which I intentionally caused-this should be a non-issue.
Old May 6, 2006 | 03:04 PM
skateparkdave
Ok, now we're getting somewhere.
My notes and code sheets are for my 1990 and they dont show codes 31 and 37 at all. The "H" stands for history. Which means they could be old and now fixed but not cleared. To clear codes just unhook the negative terminal of your battery for 15 seconds and reconnect. Then run the car for a while and check for current codes.
My list shows code 33 to be MAF circuit, then 35 to be IAC circuit.
It shows 64 to be a lean exhaust O2 sensor code but thats for module 1 and not 9 which is ABS/ASR module per list above so I dunno.
Hope this helps.
Old May 6, 2006 | 04:09 PM
lt4red's Avatar
lt4red
This is from the 96 service manual. A 1 indicates these are stored codes for the ccm.
h31-lcd data circuit shorted to b+ or ccm internal open
h33-data clock shorted to b+ or ccm internal open
h35-data strobe circuit shorted to b+ or ccm internal open
h37-m clock circuit shorted to b+ or ccm internal open
These all point to either a wire in the lcd circuit shorted to a 12 volt power source, the lcd display has an internal problem or the ccm itself is bad.
9 indicates the abs/traction controls system.
h64-throttle position signal malfunction
A indicates the Diagnostic Energy Reserve Module which is part of the airbag system and no codes are set.
The ccm then displays a 1.0 when it has finished.
Every module in the car has its own set of codes, and the ccm can display them, as you've already done, but the codes do not necesarily cross reference to other years and a code 31 for the pcm is not the same as a code 31 for the ccm. Hope this helps.
Old May 6, 2006 | 04:29 PM
USCG's Avatar
USCG
The '96 Helm manual (for my '96 car) shows me those LCD codes, but in another section of the manual also shows the same code numbers applying to the rear wheel sensors. The "9.H64" code correctly (I feel) points to the TPS, but that should be a PCM code, not an ABS code ???
So at this point, I don't know if I have a wheel sensor problem or an LCD problem.
Anyway, I cleared the codes per the manual using the trip/odo and holding the eng/met. Now, I only get the C12, which I assume means that all is well. However, this method did not clear the 9.H64. I'll do that by disconnecting the battery terminals. A little preventative maintenance on the terminals is probably needed anyway.
Old May 6, 2006 | 04:53 PM
lt4red's Avatar
lt4red
Page 5e2-23 under abs/tcs. The tcs does a diagnostic check and the tps sensor is one of the inputs to the abs/tcs. When you unplugged it you set a code.
If these codes were displayed under "9" then yes they would be for the wheel sensors. Remember each system has it's own set of codes. If they are displayed under heading "1" then these are ccm codes.
Old May 6, 2006 | 05:12 PM
USCG's Avatar
USCG
The 31-37 codes were under the "1." which indicates CCM, thus the LCD/clock/square wave thing(?) described in the manual. I'll disconnect & charge the battery, clean the terminals, and road test tomorrow and report back. Thanks for the help so far.
I thought I had read hundreds of tech issues on this site and the others (GM, LT1, etc), and this is the first I've heard of the paperclip trick working on the 16 pin connector. Does it only work on the Corvette, or any 16pin car?
Old May 7, 2006 | 04:10 AM
skateparkdave
It may have been Corvette exclusive at the time, who knows? I'll have to look in to it when I'm not this tired. I saved the info I posted earlier a few years back from a reputable c4 corvette site thats no longer around or it changed. I lost track of it.I know Vettes over the years have acted as prototypes for alot of GM technology they use on all their lines of cars today so it wouldn't surprise me. Seems like engineering learns it's lessons on the track with the "R" cars and applies it to the Vette line first for a time and then rolls it into other lines of their cars. Not just racing lessons but everyday mundane operations of efficiency as well. Just an observation I've had over the years.
To Volts read "sys" not 14.3
