Trackman Is Back In Action...
Old May 6, 2006 | 01:07 PM
TRACKMAN2's Avatar
TRACKMAN2
Default Trackman Is Back In Action...
Allaylouya Car Is Done!!!!! I Wiil Be Sure To Have A Hole List Of Interesting Problems For Yins (pittsburgheze) To Ponder...
First ,where Does The Computer Get The Rpm Signal .... Scan Tool Says 2000 Rpm Higher Than Actual Figured By Timing Light..and Tach.. I Was Told The Tach Gets Its Signal From A Different Place....i Dont Want The Rev Limiter To Kick In Early...
Second What Is The Prefered Way To Bleed The Cooling System. Seams Simple But .......
New Motor Seams Very Good Time Will Tell
