SYS light...whats up with this!
Old May 6, 2006 | 03:40 PM
RRT vette's Avatar
RRT vette
Default SYS light...whats up with this!
My 95 auto FX3 has a SYS light that comes on next to the speedometer. It flashes where you would see the digital coolant, inst MPH, oil temp, and avg MPH readouts. It flashes 3 times one second apart and goes out for about 12 sec and flashes 3 times one second apart again...and so on. I have a SERVICE LTPWS, LOW/FLAT TIRE, and PKE warnings on the DIC. The first two are due to the tire shop cutting the band on the tire pressure sensor on the right front tire so its not on the rim...I know that. The PKE is on because my fob quit working and is trash...I know that. But why is the SYS flashing? Any suggestion of previous instances.
EDIT: I have battery disconnect switches on the neg and pos terminals and the car get driven once every 2-3 weeks...50,500 miles on the clock.
Didn't see this before posting http://forums.corvetteforum.com/show....php?t=1384791
Old May 6, 2006 | 03:56 PM
RRT vette's Avatar
RRT vette
Tried the paperclip in terminal 4 and 12 and get:
1. C81
1. H81
9. ---
A. ---
1.0
In this order. I don't have the 95 FSM's with me now... there 2 hour drive away. Can someone tell me what the C81 is?
Old May 6, 2006 | 04:26 PM
lt4red's Avatar
lt4red
my 96 manual shows a c means "current" and h means "history" but they both point to invalid vehicle configuration. From the manual,
" a dtc 81 will set when startup has occured and the ccm's stored engine configuration does not match the config. info received from the pcm." Unless you replaced the ccm or pcm recently, my guess would be a ccm problem.
Old May 6, 2006 | 04:33 PM
RRT vette's Avatar
RRT vette
Thanks Dave, yes I did not mention this. The CCM in my car took a dump and was replaced with a 96 CE CCM. So the SYS light will be on FOREVER
Old May 6, 2006 | 04:38 PM
lt4red's Avatar
lt4red
I'll have to check on this, but I think the ccm stores the mileage readout on the lcd display. If your mileage readout has changed, then I think you only have 100 miles before the ccm locks and the car won't start. It has to be reprogramed by a very expensive tool that only dealers have. I think it's called a "tech II" but not sure. This is done to prevent odometer rollbacks.
Oh, and btw, names Andy.
Old May 6, 2006 | 04:43 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Hey. I got your PM. My 90 doesn't have a code 81 but here's a list I just found from a google search that may help you.
http://chevythunder.com/199295_lt1_trouble_codes.htm
Old May 6, 2006 | 04:48 PM
RRT vette's Avatar
RRT vette
Sorry Andy, my mistake and I apologize. The CCM was changed about 5 years ago. The CCM does hold the mileage but no problems with locking up.
Old May 6, 2006 | 04:56 PM
lt4red's Avatar
lt4red
No prob, glad I could help.
To SYS light...whats up with this!
