build sheet
Old Aug 22, 2001 | 10:05 PM
90 turq rdstr's Avatar
90 turq rdstr
Default build sheet
Has anyone found the build sheet on their Corvette? If anyone has, in what area do you look? :confused: :confused: :confused:
Old Aug 22, 2001 | 10:12 PM
C4RAG's Avatar
C4RAG
Default Re: build sheet (90 turq rdstr)
Top of the tank usually... Gas tank that is... If not there, who knows... Even if it is there, probably pretty bad shape... $30 or $40 at the corvette museum site and worth it to not have to drop the tank... :cheers:
Old Aug 22, 2001 | 10:25 PM
KNCRSR5R's Avatar
KNCRSR5R
just got mine out!!!!
about 40% of the one from the gas tank..........
nOw for the second one!!!!!! It is in the left from frame cross member! There is a hole behind the sway bar that you can see down in. There is another hole to the same passage on the opisite side of the crossmember. Then inside the engine bay...behind the steering shaft down low there is another hole to the same passage. I had the best luck with a coat hanger that was "strategically" bent...and LOTS OF PATIENCE!!
I got about 95% of that one! It was harder to get to and was more dirty but it was all there and NOT GLUED IN!!!!
Hope this helps!!!
:D :D
Old Aug 22, 2001 | 11:27 PM
Hi-yo-Silver's Avatar
Hi-yo-Silver
Dug it out of the hole in my frame.....in about 50 pieces! Took a couple of hours to tape it together.:crazy: I also ordered a brand new build sheet and original window sticker from the National Corvette Museum.:D Nice touch for nice cars! :cheers: :crazy: :chevy
To build sheet
