I've been reading this forum for a year now and this is my first post. Incidentally, you guys are really super! I just wish I knew 1/100th of what many of you know.
Wife blew me away with an 86 iron head a few years ago for our 20th anniversary. It was very neglected but I finally got that Vette I have wanted since I was a kid so I have been giving it some of the TLC it deserves. As with you guys, I don't have a wad to throw at it, it's more a project of love (don't tell my wife I said that).
I have done a number of projects but have a bunch more to go. Right now I am focusing on a smell. When the engine gets hot I smell something burning. I have a power steering leak but that's not it. It smells like burning radiator fluid. Sure enough, I recently found a deposit of greenish fluid under the EGR pipe on top of the head. It looks like there are burnt deposits in there as well.
My questions is can I assume the leak is coming from what looks like the (heater?) hose right next to the EGR pipe? If so can I just replace it or are there bigger concerns. I can't find anything in the Clymer shop manual on it but I figured you guys would know. Please tell me it's a cheap fix!
Mine is an 85, but I have helped a friend with his 86. The 86 has a "T" that comes off the heater hose and goes to the intake next to the distributor. Where it enters the intake it is a metal tube that has been flared and has a screw fitting that screws into the intake. Dry this area off real good then start the car. You will probably find coolant coming from this fitting. If so, try tightening the fitting. There is nothing else back in this area with coolant on top of the intake. The only other areas that coolant would come from are at the front of the engine and they would have to work their way back .... you would find a trail of coolant leading back.
From: The reason time exists is so everything doesn't happen at once
I'm not familiar with this and don't know how complete it is. I suggest you get the Helms service manual specifically for you 86. Probably the best investment you can make.
Let us know what you find.
Thanks for the info. I gt the engine temp up and went in to check. Sure enough, there was a small deposit of fluid. It is pretty hard to see anything behind the EGR Insulation shield so I got a screwdriver and rubber banded some cloth to the tip. I dabbed arond that nut but it was dry. Then I dabbed around the bottom of the hose and it was wet. So my guess is it is the hose connection.
Can I just replace it? I assume a parts store will have that type of hose I need. Do I need to worry about radiator fluid discharge when I disconnect or anything else?
I have read that a number of times in the past. I think I will take you up on that advice. Thanks.
Dave, you should be able to get the hose at most auto parts stores. It just has to be able to handle hot fluids. I would let the engine cool off and get ready to do a FAST switch. You will lose some fluid, but not too much.
GOOD LUCK
Did it - worked! If there is anything I've learned it's that a percieved simple repair probably means I'm about to screw something up. I wanted to check with the experts to make sure the solution wasn't more difficult than I thought. This one was easy. Thanks for your help! On to the next project!
