code 32 set on highway?
Old May 7, 2006 | 12:11 AM
Bubba91's Avatar
Bubba91
Default code 32 set on highway?
Since I've had my vette (year&half), I've had the code 32.
I cleared the code and didn't get it back until I ran it on the highway.
I remember reading a post about this, and tried to find it on the search, but that only led to frustration .
On my scanner it shows the egr opening and closing, the O2 is all over the place (I understand that's a good thing).
At idle my tps is ay .44?
I saw the code get set as I was driving on the highway, becauase I had my scanner on my lap and was checking specifically for that.
Any ideas?
Thanks?
Old May 7, 2006 | 12:29 AM
vader86's Avatar
vader86
EGR solenoid/switch usually, it just happens to function in hwy use more because you meet all EGR conditions there.
TPS should be .54V
Old May 7, 2006 | 01:02 AM
Bubba91's Avatar
Bubba91
TPS should be .54V
I read on a post that a '91 doesn't have a switch; so should I presume that the solenoid is the culprit?
Can I adjust my TPS using my scanner?
Old May 7, 2006 | 05:00 AM
CMYC4GO's Avatar
CMYC4GO
This is just going on my thread about the dreaded "code 32"....
Somebody mentioned that you'll get the code on the highway, especially when you're using the cruise. Something about the throttle being in a constant position for 5 or 10 minutes.
Old May 7, 2006 | 01:50 PM
Bubba91's Avatar
Bubba91
Does this mean I have nothing wrong with my vette?
Old May 7, 2006 | 02:54 PM
vader86's Avatar
vader86
If it sets the code, then you need to troubleshoot EGR. You'll need to go through the manual.
See my website for TPS/IAC cleaning procedure, you need to do this before replacing any EGR parts. Always fix things at the front of the intake tract first.
Old May 7, 2006 | 04:24 PM
Bubba91's Avatar
Bubba91
Thanks charlie, I'll check it out.
Old May 7, 2006 | 04:50 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Does the 91 have the egr Temp switch on the crossover?If so,see if its broken or coming apart,very common cause of code 32 on certain L98's...same with egr vacuum lines,make sure they all fine and not broken.
Old May 8, 2006 | 10:16 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Check the EGR valve itself, too. The diaphragm on them can break or they can get clogged up with carbon to the point they no longer function.
Old May 8, 2006 | 09:19 PM
yellow dragon's Avatar
yellow dragon
the 91 doesnt have a temp switch, same thing happened to my 91, EGR solenoid is probably the culprit, mine was the park nuetral switch on the shifter, but that is the rare case
the EGR system comes on when the motor is up to operating temp and you are at a cruising throttle, it wont come on at high throttle. Thats why it comes on durring highway driving, that means the system will not turn on. The system itself is designed to reduce combustion temps by reintroducing exhaust gas into the intake, the LT and LS motors dont use is because they have reverse cooling.
Old May 9, 2006 | 09:01 AM
onedef92's Avatar
onedef92
The LT1's have reverse flow heads and EGR systems. The LT4's do not have EGR's
Old May 9, 2006 | 06:00 PM
yellow dragon
how did the LT4's get around egr if the LT1 had it
Old May 9, 2006 | 06:53 PM
vader86's Avatar
vader86
LT4 camshaft has enough overlap to make EGR redundant.
LS engines dont use it because they just dont need to, not because of the cooling.
Old May 9, 2006 | 09:34 PM
CMYC4GO's Avatar
CMYC4GO
I had a performance chip installed in mine, with an EGR delete, and had the fans set to come on @210. It was also suggested that I get a cooler thermostat. Will an inoperable or deactivated EGR system cause combustion chamber temps to reach critical levels, or does it only involve a mild increase in temps? After having the chip installed, I drove the car around 200 miles on the Interstate, and if there was any difference in performance, it was definitely better.
Old May 9, 2006 | 10:45 PM
blown66's Avatar
blown66
My 92 did the same thing. I got a can of cat converter safe throttle body spray cleaner and gently lifted the pintle and sprayed it around the opening. Been fine for over a year now. Got that tip here by the way.
Old May 9, 2006 | 11:12 PM
vader86's Avatar
vader86
No not terribly high, but fans dont activate at highway speeds either so your fan setting doesnt matter. They suggested a lower temp stat because temps will equilibrate lower with it installed, helping soak up any heat that the EGR wouldve dissipated in the chamber.
To code 32 set on highway?
