Brake Master Cylinder Overflowing
Old May 7, 2006 | 04:16 PM
jimmers's Avatar
jimmers
Default Brake Master Cylinder Overflowing
I have a 90 with a brand new brake master cylinder. For whatever reason one reservoir will go low and the other will overflow. Any idea as to what is casuing this? Brakes have been bleed and they work great. Thanks for the help.
Old May 7, 2006 | 04:43 PM
Quiktrp94's Avatar
Quiktrp94
I think you need to return it for a new one.It sounds like one piston is leaking and forcing brake fluid past the other and filling that res.
Old May 7, 2006 | 06:32 PM
flyinlow90's Avatar
flyinlow90
Mine was doing the same thing. I read somewhere that that was a sign of the master cylinder getting ready to fail so I replaced mine.
Gary
Old May 7, 2006 | 08:40 PM
jimmers's Avatar
jimmers
Well thanks for the replies guys. Seems weird to me that its doing that already. Maybe I got a faulty one. Thanks
Old May 7, 2006 | 09:22 PM
Red Tornado's Avatar
Red Tornado
you did indeed get a bad "new" one.
my dual cylinder needed replacement at 75,000 miles. same symptoms: front cylinder leaking into the rear one (internal piston/seal leak). then the excess from the rear one decides to upchuck onto the (hot) brake booster so you can that nice burning brake fluid smell from under the hood
by the way, here's to you, from one red '90 to another
To Brake Master Cylinder Overflowing
