hesitation
Old Aug 23, 2001 | 01:03 AM
allious's Avatar
allious
Default hesitation
my 84 vette has developed a hesitation at partial throttle. at lower speeds if i press the gas, it kind of "flutters" before it seems to catch up and run very strong. i have installed a new tps, adjusted timing, and changed fuel filter. i have true duals with no cats. does anyone know what could be the problem?
Old Aug 24, 2001 | 06:22 PM
allious's Avatar
allious
Default Re: hesitation (allious)
Old Aug 24, 2001 | 11:58 PM
TAguy's Avatar
TAguy
i have the same problem on my 84 vette and mine sputters if i try to do a donut and it hesitates real bad if i floor it from a dead stop or even just try to take off moderatly. i replaced the fuel filter, the IAC solinoids, the EGR valve, intake and cover plate gaskets, throttle body gaskets, timing chain, oxygen sensor, and all hoses. i have good compression and the valves are opening and closing all the way. all this and it still runs like crap. it has to be a fuel problem. if you get any good help please rely the cure on to me. thank you
To hesitation
