ZF 6spd fluid change
Before jacking the car up, i've searched through my service manuals for fill/drain plug locations, but i'm having some trouble locating them.
Are they fairly obvious to see once i have the car on jackstands? Will i need a pump to fill, or is it accessible through the engine comparment?
Anything i should look out for?
thanks for the input!
Great! Thank you...
You will need a pump or syringe to fill the transmission. I bought a big syringe from Autozone when I bought the allen sockets for about $3.
You'll need a tad over 2 quarts of the GM fill, or the BMW fluid. I don't have the part numbers handy right now, but if you do an advanced search in the archives for "ZF6 fluid" you should be able to find the part numbers fairly easily. The original GM fluid is tough to find anymore, and no one can say 100% that the replacement fluid is 100% compatible with the ZF6. The BMW fluid is the only other GM approved fluid fill for the ZF6 that I know of, and it was a ton easier for me to find. It's also the recommended fill by Bill Boudreau, who is probably the most knowledgeable person in the United States when it comes to ZF6 transmissions.
Good luck, and let us know how it turns out.
Oh, and for what's it's worth the search function would of answered this question in literally less than 10 seconds. There is also another thread about this on the front page. If you take a minute or 2 to look around before cluttering/clogging up the forum with common questions it makes it easier on all of us.
Also, I bunged up one of the plugs, buy an extra or two before the project.
i'm not sure 10 seconds,
as i did search the c4 section for the following:
"manual Transmission Fluid Change"
"Change Transmission Fluid"
"Transmission Fluild Plug"
"Transmission Fluid manual"
"transmission Fluid"
Maybe i'm not searching correctly?
I Always use the search feature.. i've been a member for over a year, visit every day, but only posted a handful of times.
i agree.. the search feature is extremely helpful.
Here's a snippet from the PM I just sent you. Maybe someone else can use this info too:
Advanced search works everytime.
Type you search text, in this case I would of searched for "ZF6 fluid." Check the box for "Titles only." Next, go down and select the box to search the archives along with the current threads. Anything older than about 3 months get's archived, I suspect that's why you didn't find anything in your searches. Scroll the menu down and select the header for the C4 section, this will tell the search engine to search the entire C4 section. Finally, click search.
That should turn up 24 answers.
but unless "zf6" was entered even in the advanced search, you get nada.
That's where i went wrong..
Thanks to all who replied to the apparently redundant thread.. this weekend i'm refreshing the fluids.
I am happy w/ the bmw stuff.
Check the C4 Tech FAQ stickey (scroll down to Fluids) at the top of this section.
all three $10 bucks. I bought the allen wrench I needed for the differential from Westlake for alike $1.89.
I'm a bargain shopper.
Additionally, if you re-torque fill and drain plugs to values recommended in the factory service manual, you can use a torque wrench with the Snap On tool. I am not sure if other listed tools above can be used with a torque wrench. I'm pretty sure I've seen less expensive tools in other stores that could use a torque wrench but can't recall where. Besides, that tool is made in America, a rare find.
Good luck with your task.
By the way, a 90 with such low miles, hard to find.
dlmeyers, 90 coupe zf6 3speed shocks
