What does "volt" mean?
Old May 9, 2006 | 09:53 AM
96er's Avatar
96er
3rd Gear
Default What does "volt" mean?
Hello all. I am looking into buying my first Corvette this week, a 1996 A4 coupe, however, on the digtital read out below the speedometer it says "volt". What exactly does this mean? The car is going to my mechanic today for a prepurchase inspection, but I would still like to know exaclty what that means.
Thanks!
Old May 9, 2006 | 09:58 AM
vader86's Avatar
vader86
what is your voltage reading?
Old May 9, 2006 | 10:00 AM
RFDrpm's Avatar
RFDrpm
Battery voltage incorrect = too high or more likely too LOW
Old May 9, 2006 | 10:02 AM
bogus's Avatar
bogus
the speedo on the 1990-1996 C4 will present voltage, coolant and oil temps when the "Gauges" button is pressed on the DIC. Press the big Fuel button and it will return to displaying the odometer.
Old May 9, 2006 | 10:30 AM
96er's Avatar
96er
3rd Gear
Ah yes! That makes sense. Thanks for the replies everyone.
Old May 9, 2006 | 10:25 PM
Insane1's Avatar
Insane1
Where is this 'Gauges' button? I don't remember seeing it on my 90 vert.
Old May 9, 2006 | 10:43 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Not sure if the 90 has a "gauges" button. There is a difference between 90-91 and 92-96 on what buttons are on the DIC.
Old May 9, 2006 | 10:44 PM
NEVRL8T's Avatar
NEVRL8T
On a 92 coupe it is directly below the "fuel" button.
Old May 10, 2006 | 03:31 AM
ToniH's Avatar
ToniH
1990-1991 does not have this feature. Sadly only analog gauges for voltage and temperatures.
Old May 10, 2006 | 04:48 PM
Insane1's Avatar
Insane1
Damm. I like the digital gauges. I wanted to make sure my gauge was correct since I put on the reverse glow gauges.
Shame on you Bogus for giving me bogus information and getting my hopes up.
Old May 10, 2006 | 06:22 PM
95wht6spd's Avatar
95wht6spd
This is exactly what it means:
The International System unit of electric potential and electromotive force, equal to the difference of electric potential between two points on a conducting wire carrying a constant current of one ampere when the power dissipated between the points is one watt.
Old May 10, 2006 | 06:36 PM
bogus's Avatar
bogus
yea, that's me, Mr Misinformation
Old May 10, 2006 | 06:37 PM
bogus's Avatar
bogus
Named for some Italian dude named "Volta," if I remember rightly.
To What does "volt" mean?
