My '92 LT1 has the warm weather blues again... As usual.
My question to the pro's is:
Can an injector(s) malfunction after reaching operating temp or above, say 220 degrees, and not have any issues when cold? If so, can they be heated (after removal) and tested?
I'll be checking the oil later today for evidence of fuel in the pan.
Sure - check resistance across the coils hot and cold - no need to remove them, just warm up the engine. Specs are 10 ohms or higher - most check out at around 16 or 17 ohms with a little bit of a drop (like an ohm) warmed up. All should be the same, wide variances need to be replaced.
but I'm not sure it has to be a wide variance, mine all ohmed within .5 I've owned it for 7 yrs., I'd say if you found 1 or more 1+ ohms out you've got some problems-and more to follow.Thought I read somewhere they should be within .5 of each other...but the old memory is slippin.
of course it could. Anything electrical starts to change resistance and such as it warms. but this is also why the fuel is pumped through them... to keep them cool!
Isn't that the same question, that's why you ohm them hot and cold.Answer...sure! If you'd like to see the results of a injectors testing bad..look at 87 Rag s last post by myself and mudslides problem.
