Nitrous express
The Powerstar systems I sell are also of the single nozzle variety, and thus far everybody I've sold them to are very satisfied (just ask Legion21 about his, for example!). I've extended the "forum special" pricing on these for the time being, so drop me a PM if you're interested.
Greg
Pull 2-4 degree's out of the engine by turning the distributor, and just live with the slight power loss when you're running no juice. Once you can afford the ignition box, hook your new box up and verify that it is pulling timing by activating the N20 system with the solenoids disconnected and a timing light on the engine. Once you know the box it working, put the 2-4 degree's you pulled back in by setting the distributor back where it was.
....one split second of going lean on that shot and the motor will be toast
sorry been doing this for so long that I forget to fill in the blanks.. i have a window switch,fuel pressure switch and also a a/f switch, and audible knock sensor.
I always run at 900psi always.
pulling timing is always a good thing and you may only lose max 10hp when not on the juice
If this were true, why is NX saying not to pull timing. That defeats the whole purpose of running a wet kit system. That is why the fuel is there, to prevent the need to pull timing. NX has had YEARS and YEARS of experience with this stuff, I'd trust them.
I run a 150-shot NX kit with an independent fuel system, the only other add ons I have on the nitrous is a window switch and low fuel pressure cutoff switch. I use a fuel pressure regulator to get the right AFR at WOT from about 4k rpm on up to 7500. With the right amount of fuel, your AFR should read right with little to no knock.
Granted, most people don't have the type of setup I have, but you can still do something similar without pulling timing. In 99% of all situations, you can tap into your stock fuel system up to 150-shot without starving your injectors, but to achieve your desired AFR, simply bypass your fuel line with a regulator so you can adjust the pressure.
You can pull timing if you want to, but then why bother running a wet kit, just go dry and save the trouble. Just my $.02.
