Another LT1 ignition problem - continuing saga!
I noticed we have a source on this website - Zip products here in the Corvette Store has one for $96 ($150 core exchange) - can anyone vouch for this vendor? The link to the part is:
http://www.zip-products.com/Corvette...5A74FE703EC6D4
Again, many thanks to Lani and everyone else who has assisted me on this issue - I'll post when I've got more to report on!
Climate control is known as the C68 Controller or HVAC controller.
Not sure if the page numbers will be the same but look at VIN P engine Runability section (first part of book 2) and look up Ignition Control circuit. DTC 41 page 6E3-A-73.
Sorry about that, EBTCM = Electronic Brake Control Module (ASR) Your year may not have that, not sure.
Right but you that doesn't tell you if you have an IC (integrated circuit) chip with a gate failing when it gets hot. Continuity is check to ensure valid primary and secondary data lines are known good.
Same here mine replacement the cover looked like them spray painted it black in the desert. All kinds of crap in the paint they don't seem to bother to clean up the covers.
Yes when I tested mine old tach filter after it was out of the vehicle it was really low on resistance.
Could be, I wouldn't be surprised if the reman'd ECM is failing again.
Matter of fact I'm looking at my ECM again too, as I'm getting symptoms that are beginning to mimic what I experienced before. So I'll be giving Chris a call to discuss warranty issues.
Got stuck having to go out of town on business. It ended up being a real problem getting an ECM locally - do not carry, out of stock, etc.
I finally got a reman unit yesterday (its a Delco reman - they don't make OEM anymore) - installed it this morning - same thing - engine spins over happy as hell, no start - no spark. Damn!!
After going through the complete flow chart, and having checked all circuits between ECM, ICM, coil and Opti, as well as having changed out the coil, ICM and now the ECM with no effect, I am stumped.
The only thing that hasn't been removed and checked is the Opti - this would be the third time for me and I was hoping not to have to do that I'll tell you!
Just had a thought - may be a weird question, but here goes - can an EEPROM go bad (have a heat-soak intermittent connection that finally went out) and could this be the root of my problem? We're expected to just assume it's good; since this part is swapped between all the three ECM's and is not a service part, could it be at fault? On the other hand, if it is the Opti, can it be bad without the ECM throwing any low or high-resolution codes when the engine shut down on me?
Is there any resource out there for testing an EEPROM?
Opinion? Thanks much for your help - sure wish that new ECM would have done the trick!
Based on all the data gone through above and having ruled out the computer, I bit the bullet and ordered a Gen I Dynaspark from Eric - trying to do this at the same time as pack for moving day - finally broke out enough time to finish this up.
Got the Dyna in, everything else bolted up with no parts left over - she fired right up and I'm now officially back in business!
I can see why the OEM unit went - had 60K on the clock. But, does anyone have any clue why both the reman Opti and then the AC-Delco I bought two years ago bit the dust so early - I swear I haven't driven more than 1000 miles a year over the past two years, always nice weather, no water issues either; always covered/garaged too -
Wish me luck that I'm not gonna have to do this again - glad I've got the warranty with Dynaspark just in case!
Yeah, I'm gonna fix that - you are right though, sure seems the Vettes that run the best are run the most - no more garage queen for me!
My guess just not enough driving.
It you don't, your ICM will stir-fry itself to death shortly from engine heat.
I presume that if the ECM saw no pulses from either of the sensors, it would not set any Opti codes, but I can't state this with absolute certainty. I can promise you the engine wouldn't start.
If the center contact (coil) of the distributor cap is severely carbon-tracked to engine ground or to another (spark plug) contact of the cap, I can see where it could also cause a no-start and it definitely wouldn't set any Opti codes (but you would have found spark at the coil when you checked it).
If this occurs again with the fault apparently being in the Opti (Dyna in this case) and no Opti codes set, I'd suggest you very carefully check out the harness and connections between the Opti and ECM, because I'd suspect there's an intermittent open circuit in there somewhere (probably on the power feed line).
Good luck. Hope it stays operational this time.
Be well,
SJW
Arctic Silver 5 is my favorite thermal compound...I use for all my computer CPU's. And it is important to spread entire area with thin film, 'cuz if you miss a spot......yes, you will have a Hot Spot!
http://www.arcticsilver.com/as5.htm
There was some discussion about moving it so that the sink was insulated from the head itself and would not absorb the heat from the head (but still using the thermal compound).
Does anyone have any experience or commentary about this tech tip?
http://shbox.com/1/how_tos.html
Twinmap.
As I recall (and will probably be corrected), with the spacing, the sink will heat up quicker, possibly even run hotter, and cool off quicker.
As originally installed (without the spacing mod), the head itself adds to the heat absorption, somewhat modulating the heat cycle of the actual sink. I don't know any of this from first hand experience, have not done any thermal tests, etc. Just what I recall reading.
Again, just wondering if anybody had something concrete to add other than pure speculation.
