problem muflers/egr
Old Aug 23, 2001 | 04:05 PM
corvette90's Avatar
corvette90
Default problem muflers/egr
Hello guys..
Again, my question...i want a 90 6-speed sound like a real corvette should..
so i will make two muffler attraps myself..
Will this set a SES-light..?
i don´t mind code 32, as long as this will set no SES-light..
I asked a local chevy dealer, and he told me no problems with this light so far,...
thanks..
Old Aug 23, 2001 | 04:22 PM
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
Default Re: problem muflers/egr (corvette90)
Changing mufflers will have effect on engine codes -- it won't set the SES light
Old Aug 23, 2001 | 04:39 PM
TrplBlk01's Avatar
TrplBlk01
I just got muffler elims and no prob here.
Old Aug 23, 2001 | 06:59 PM
David-F's Avatar
David-F
Default Re: problem muflers/egr (blk91)
Just changing mufflers alone will probably not cause a problem with the EGR valve but remove the front cats and install a high flow main cat and on a highway cruse I'm sure you will get a code 32.
David Fulcher
Old Aug 24, 2001 | 01:11 AM
92corvette's Avatar
92corvette
THe eliminators set a code 32 and a couple other codes on my 92. Put in a chip to fix the codes.
Old Aug 24, 2001 | 01:32 AM
corvette90's Avatar
corvette90
Default Re: problem muflers/egr (92corvette)
ok, thanks..
So does this mean, i maybe get a code 32, but the SES-light wouldn´t be set??
will every error code set the SES-light, or what depends this light on??
Old Aug 24, 2001 | 01:35 AM
pablocruise's Avatar
pablocruise
I put flowmasters and no prob here. They are quiet.
Old Aug 24, 2001 | 09:25 AM
David-F's Avatar
David-F
Default Re: problem muflers/egr (89 Paul in cal)
On a 90 any ECM code will turn on a SES light.
David Fulcher
Old Aug 24, 2001 | 02:01 PM
Larrym96815's Avatar
Larrym96815
So what is code 32? I have a high flow main cat and Flowmasters on my 91 and have had no trouble.
Larry
Old Aug 24, 2001 | 10:28 PM
corvette1990's Avatar
corvette1990
Default Re: problem muflers/egr (Larry Mackey)
Ditto: I have TPIS headers with the EGR hookup, a Random Cat High flow, and muffler elims and NO codes. Was that because I have a custom Chip? Hmmm. :crazy:
To problem muflers/egr
