Bosch Injectors
OEM-22lb
8/Set: $249.50 I guess these are the ones for my 1990 L98--Yea they are pink. now where can I get the gasket set with the o-rings and what ever else I need--I tried summit, but it keeps showing me intake gaskets
What does factory take outs mean?
Thanks guys
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Most of the parts stores will have a complete Felpro gasket set for $25 or so, or you can just buy the upper gaskets. The one I bought came with 8 injector orings.
Mudslide, Where did you find injectors for $249! Hook me up brother.
I've been looking for weeks for OEM type injectors for my L98 Camaro.
Eagle
I used the Felpro TPI intake gasket set from Summit part# FEL-MS93318 $28.39.
The only thing that wasn't correct was that this set comes with two different size o-rings for the fuel lines but, on my "91" both o-rings are the same size. I just reused the o-ring for the fuel return line.
