ABS unit cycling
Old May 11, 2006 | 01:58 PM
Yguy's Avatar
Yguy
Default ABS unit cycling
Getting ready to do a brake fluid flush in the near future. When I do this, is there a need and a way to get the ABS unit to cycle in order to
flush the fluid in there also? Should I even worry about it?
I'm looking at going to braided lines, $110/set from MAD, Ecklers, C-Central.
Thanks in advance
Old May 11, 2006 | 02:14 PM
Tom Piper's Avatar
Tom Piper
I think it may depend on the year of the car.
My '92 has a dedicated brake fluid "primer" pipe from the master cylinder reservoir to the ABS/ASR unit and a bleeder valve on the unit too.
The '92 shop manuals don't have anything in them about special procedures for bleeding/flushing the brake fluid separately through the ABS unit.
And, the manuals for the Vetronix Tech-1A don't have any instructions/features for opening the ABS valving for a flush on a '92.
But, I don't think later ('94 and up?) have this primer pipe.
Tom Piper
Old May 12, 2006 | 12:29 AM
Yguy's Avatar
Yguy
Thanks Tom.
As I said in my starting post, I'm not even sure it needs to be done.
But if I'm gonna go to the trouble of a flush, I want to do it right.
Old May 12, 2006 | 01:54 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
I flushed Mine using a Mityvac and did not cycle the ABS.It worked fine and improved my braking.The MC looked black before and is clear now.I guess that is the diagnostic aid. If it is black bleed time for sure.I used synthetic fluid too.
Old May 12, 2006 | 06:15 AM
Tom Piper's Avatar
Tom Piper
According to my Ford shop manual, my Ford truck requires a scan-tool to open the ABS valves for flushing the entire system.
So, obviously, it depends.
The problem with not making sure the ABS unit is flushed/bled is:
1) If there is air in the ABS unit, the brakes will feel fine until the first time the ABS unit pump runs and the valves open during an ABS event, then the air will be pushed out into the rest of the system and you will have spongy brakes.
2) If the fluid in the ABS unit is contaminated with moisture or debris, the first time it is cycled that contamination will mix with the rest of the system.
Tom Piper
To ABS unit cycling
