ICM? Opti? Ideas?
Old May 11, 2006 | 06:51 PM
n1kki6's Avatar
n1kki6
Default ICM? Opti? Ideas?
Figured I would start new new thread about my problem to outline in one post.
Was backing out for work the other day and the car died. Started back up and died again.
Fuel Pressure is good - 42 PSI
The two plugs I checked are getting spark
A month ago water pump went, replaced it, didnt do the opti.
I have an opti on the way but the idea of the icm going was brought up. Is their anyway to test the icm? Would be car die while backing up if the ecm went.
The car wasnt missing but it did seem to be low on power but that could also have been me getting used to it for the season.
No codes are showing up.
Its a 94 with 125k. I bought it with 65k and have never changed the opti and am not sure if it was changed before then.
Old May 11, 2006 | 09:17 PM
n1kki6's Avatar
n1kki6
Should I just put an icm in and see if that does it. I am really at a loss.
Old May 11, 2006 | 09:27 PM
n1kki6's Avatar
n1kki6
Just checked the compression and that is fine too.
Also a note that night before work it was pouring out and still raining in the morning when I backed out but I didnt drive it in the rain the night before.
Old May 11, 2006 | 10:21 PM
LT14FUN's Avatar
LT14FUN
I feel for ya! If you check other threads on the Forum, you'll find some posts that say AutoZone can check your ICM - around here (SE Wisconsin), they can't or won't!
Does your Vette fire at all or are you dead in the water like me?
Old May 12, 2006 | 12:15 AM
n1kki6's Avatar
n1kki6
Its turning over just wont start. I just replaced the coil and that didnt do it. I will call autozone tomorrow about the ICM, if thats not it then in goes the new opti and hope thats the problem.
Old May 12, 2006 | 01:49 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
The FSM has detailed flow chart on testing the ICM that is how I confirmed my own diagnosis.The FSM is cheaper than throwing parts at it.
Old May 12, 2006 | 08:15 AM
LT14FUN's Avatar
LT14FUN
Old May 12, 2006 | 09:51 AM
n1kki6's Avatar
n1kki6
Its so easy to get at I just picked one up, dude said it would be cool for me to throw it in and return it if its not it. After doing the coild the car is turning over much stronger it seems so hopefully the icm will fix it.
Old May 12, 2006 | 09:56 AM
84vette96's Avatar
84vette96
I had a no start prob. It turned out to be the coil wire. Changing good parts gets expensive and it stil wont run.
Old May 12, 2006 | 10:04 AM
Scooter 94's Avatar
Scooter 94
That's good to know. I always thought there was no refund on electrical parts. Where'd you buy it?
Old May 12, 2006 | 10:07 AM
n1kki6's Avatar
n1kki6
It was a wink wink thing at napa from someone I know through a mutual friend. Since it can be installed and tried and removed without looking any different he said it would be cool.
Old May 12, 2006 | 10:58 AM
Jerris's Avatar
Jerris
This could be the ICM ( among other things) if you have no spark and they usually die without any warning when they die.
Do not run the engine too long with the new one hooked up temporarely as they will burn out. The packet of white grease is an important part of this install and must be used or the ICM will overheat and burn out.
Old May 12, 2006 | 10:59 AM
n1kki6's Avatar
n1kki6
But I do have spark thats why I have no clue.
Old May 12, 2006 | 11:07 AM
n1kki6's Avatar
n1kki6
Just called autozone to ask about testing and they seemed to have no idea what I was talking about.
Old May 12, 2006 | 11:18 AM
Jerris's Avatar
Jerris
If you have spark then there is nothing wrong with your ICM.
If you have spark and fuel preassure then the problem seems to be that the ECM (computer) is not pulsing the injectors. Check the two injector fuses in the fuse boxes to see if one has blown.
Old May 12, 2006 | 11:27 AM
n1kki6's Avatar
n1kki6
What about this though. He had spark and it was the icm.
http://forums.corvetteforum.com/show...7&postcount=15
Doesnt the icm have something to do with timing as well.
Old May 12, 2006 | 11:29 AM
SJW's Avatar
SJW
This is good advice.
An engine needs three things to run:
1. Compression. This requires that the valve train is funcitoning correctly, etc.
2. Spark to the proper cylinders at the proper time.
3. Air and fuel in approximately the correct ratio.
You have compression.
You're getting spark to the plugs, and you're not getting backfiring/misfiring (or are you?). If there is no backfire/misfire, but rather only an apparent no-fire, it's unlikely to be an ignition-related fault.
You have fuel pressure. Good news. But are the injectors opening?
Be well,
SJW
To ICM? Opti? Ideas?
Old May 12, 2006 | 11:33 AM
n1kki6's Avatar
n1kki6
WHen its cranking it doesn not seem to be missing and its not backfiring. If I crank it for a while it sounds like it may miss once but I can't call it for sure. So I should check injector fuses. What else should I check injector related?
Old May 12, 2006 | 11:35 AM
n1kki6's Avatar
n1kki6
The injectors must be opening though because the plugs have gas on them. Which makes me think the timing is off for some reason. I was backing out and it was fine, then killed. Restarted but wouldnt stay running. Now it just turns. At first it seemed like fuel but with the water pump just going I thought opti. On lunch I will check the injector fuses.
Old May 12, 2006 | 11:42 AM
n1kki6's Avatar
n1kki6
Does the icm control the timing at all or just amplify. I just read this post and am a little lost.
http://forums.corvetteforum.com/show...58&postcount=6
